joe666joe666
Apr 28, 2026Follower
RBR750 won't apply network settings
Starting today after a restart, my RBR750 is no longer applying network settings to laptops. This also seems to have migrated to personal devices as well. So far my IoT devices are still connected. Firmware is up to date. If I manually apply network configuration settings to the laptops, these devices successfully have internet access. How do I fix this issue? And purchasing new isn't an option. If I have to go that route, it will be a different brand for sure.
Any progress on this?
What do you mean wont apply network settings to laptops?
Are they getting an IP address?
What personal devices do you have?
What OS platform is on the laptops?
Are they wireless or ethernet connected?Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the RBR in router or AP mode?
How many RBS are deployed?
RBS750s?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
