thenewbguy
Dec 08, 2022Aspirant
Rbr760 not a fan of samsung phones
I recently got this orbi kit and my phones seems to never be able to connect to the 5ghz band. I'm using a sg21 ultra and a galaxy a71 both having the same issue.
What OS is loaded on the phones?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Can you disable the AX mode on the RBR?
How is the wifi settings configured on the RBR?
Try setting manual channel 1 on 2.4Ghz and 40 on 5Ghz.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Do they connect on 5Ghz if you turn OFF the RBS?
- thenewbguyAspirantTried all those options, even standing directly next to the router with and without the satellite being on, no change
Phone is running android 12, one ui 4.1- FURRYe38Guru - Experienced User
