charlie_sn's avatar
charlie_sn
RBR850 Dropping WIFI Devices
Hi all,
I'm currently using the RRBR853 and sometimes random  devices seem to drop connection to the Wifi and then you have to reboot them to work again, the Orbi is running in Router Mode and plugged directly into an Openreach Modem. I have tried limiting devices to 2.4ghz and 5ghz respectively but that doesn't fix it, I've also tried factory resetting and that didnt work?
Firmware: V4.6.8.5_2.1.9
2.4Ghz Channel: 4
5Ggz Channel: 44
AX: Enabled
Coexistence: Enabled
WMM: Enabled
CTS: 2347
Any help would be appricated
  • Since then nothing has dropped off and now I’m rooms where I used to get 300/400 it’s now 600 so I have no idea what happened but thanks
  • FURRYe38's avatar
    What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
    What CAT# lan cable are you using between the modem and RBR? CAT6 is recommended.
    How many devices do you have all connected?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz. 4 is not a primary channel to use.
    Can do do something for us and take a look at the System Uptime on the routers IP address/debug.htm web page. Can you see if this has a long up time or does it seem to be short?
    • charlie_sn's avatar
      charlie_sn
      I believe the Modem is a Huawei HG8310M but custom made for Openreach?
      I'm using Cat6a
      Have about 40 devices connected but 10 or so are on Ethernet
      2750sqft
      Recomended distance between the 3
      Changed 2.4Ghz to 6 and it did it on another device
      No other wifi networks
      It's been up for 4hrs
      • FURRYe38's avatar
        How many RBS do you have deployed?
