russellmoran99's avatar
Feb 11, 2022
RBR850 not connecting RBS750 Satellite after switching to AP Mode
I purchased my RBR850 with 2 satellites and they work great.  I purchased RBS750 for my son's room and worked great until yesterday.  My RBR850 router function drops the connection from the internet every 2-3 days and needed to be restarted accordingly.  I replaced my router and put thr RBR850 into AP mode.  The RBS750 has been synching wirelessly but now will not.  I have even tried to move it about 3 feet and also have connected via wired backhaul.  I have done a factory reset and the 30-30-30 reset.  I am having no luck.  Can anyone assist?  All my other satellites are wired and work fine.  Thanks
  • russellmoran99's avatar
    russellmoran99
    Feb 13, 2022
    SOLVED:
    After updating all, I started reading a little more.  I saw folks using a pfSense router which I was as well.  One common denominator was making sure even though this was in AP mode, I still had to hook the WAN line from pfSense to the RBR850.  Once I did this, I rebooted the RBR850 and was able to connect the RBS750 both wired and wirelessly.
      russellmoran99
      Luminary
      As far as I know the latest. I ran a firmware update prior to moving to AP mode and everything said it was up to date. I currently can’t login to see if as it’s not connecting.
      • FURRYe38's avatar
        Need to check to make sure the RBS750 is on same version of FW.
        Can you connect the RBS750 to the back of the RBRs LAN port using a LAN cable to see if it connects?
        Turn OFF the other RBS's while working with the 750 RBS.
