karenesbs's avatar
karenesbs
RBR850 not sending IP address after power outage
This has been an ongoing issue with me for eight months now. I lose power and most of my devices cannot obtain an IP address. I then must do a hard reset (sometimes several hard resets in a row for it to finally work). After doing this several times over several weeks, I finally called Netgear support. It was determined that my router was faulty, so a new router was sent to me. When the new one arrived, I was unable to change the username and PW to my original one so I had to change all my devices. Over 100 devices from equipment, cameras, light bulbs, switches, etc. When low and behold, it happened again. The power went out and again, devises could not obtain an IP address. Oddly, I could always connect via the Guest network. Note that I even purchased a battery back up to avoid losing power, but even that switch from power to the back up, I would lose it enough to where my devises would not obtain an IP address. I called Netgear again. After several attempts, I was sent ANOTHER router. After several attempts to get the latest router communicating to everything by changing IP addresses, etc. and with my old username and password and I "thought" I was finally fixed. Nope - the power goes out and I'm back at ground zero. Now when I called, I get nothing. No one can help me, and I'm being told that they are "looking into the matter". It had been two weeks now and still nothing. Almost $2000 invested, 18 cases have been opened over eight months, I can't tell you how many hours on the phone, plus hours not on the phone resetting everything, trying to get this resolved to no avail. Netfear is the most expensive option out there, so I "thought" I was purchasing the best - boy, was I wrong. ISP is Trailwave fiber optic, modem is GigaSpire Blast. Four Satellites spanning the rural property.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    • karenesbs's avatar
      karenesbs
      What Firmware version is currently loaded? Firmware Version V7.2.6.21_5.0.20
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? ISP is Trailwave fiber optic, modem is GigaSpire Blast Model u6x GS4227
      How many RBS are deployed? This was in my original post - there are four satellites, if that's what RBS means.
      What is the size of your home? Sq Ft? 1600 sq ft, but there are satellites in other buildings on the property. All satellites are are more than 30 feet away from each other.
      What is the distance between the router and  satellite(s)? 30 feet or more is recommended in between RB and RBS
      https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite â€Śâ€Ś
      Does this happen with the RBS turned OFF? yes
      Does this happen with both wireless and wired devices? yes
      2.4 GHz Channel Auto (9)
      5 GHz Channel 36 + 40(P) + 44 + 48
