Kunson's avatar
Kunson
RBR850 satellite 5ghz automatically disabled
Hello there.
I purchased orbi rb854 suite and setup as router mode with PPPOE ISP. Three satellites use ethernet connect (use cisco switch). I used the network almost month occur few problems can't be resolve even upgrade to latest firmware (v4.6.7.5)
problem 1: use computer (side of one satellite) ping to orbi main router delpy is not stable. Mostly deplay is 2-9ms but every minute occur 100-300ms and turn back to 2-9ms.
problem 2: all clients in area lost connection. showing dhcp no IP (phones and mac computer). in this time login into this area satellite show 2.5ghz and 5ghz network disabled.
model version: orbi RB854
firmware: v4.6.7.5.
wifi-users: iphone13promax; cameras; macs.
screenshot: https://drive.google.com/file/d/1PjR-hEajMeFXkM8eg2RMLrMHFwLhNmeq/view?usp=sharing
https://drive.google.com/file/d/1mAFc1gXGnPK7BPMzEzYMDfWpRTI08mKX/view?usp=sharing
thanks.
  • If your using v5 FW and have done a full factory reset on the RBR and RBS and the RBS continues to disable the wifi radio when it's ethernet connected, it would be a HW problem. Mine have been ethernet connected since I applied v5 FW and no radios are disabled.
    NG support needs to look into this one RBS.
