JeffinDallas
Oct 01, 2025Aspirant
RBR850 Slower Than Expected
I have an RBR850 Router and an RBS850 Satellite connected to a Spectrum-provided modem. I get 1Gb DL and 1Gb UL from the modem, but the Router degrades my speeds. I'm running firmware V4.6.9.11 on e...
JeffinDallas
Oct 02, 2025Aspirant
How do I force a FW update? Here's what I see in the admin app. Thank you.
Oct 02, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Please check NG download site first:
https://www.netgear.com/support/product/rbk852/#download
Use this process to update the system manually:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
- KevinLiTOct 02, 2025NETGEAR Moderator
Hello JeffinDallas ,
Welcome to the NETGEAR Community!
I understand that you are having issues with your RBR/RBS850 due to experiencing lower than expected speeds on firmware version 4.6.9.11. The downgrade in network speeds occurs when the system is on a dated firmware. Your RBR/RBS850 is not able to pull the latest firmware due to it being out of date. Please download the most recent firmware to resolve this issue.
Please navigate to the knowledge based article below for step by step instructions on how to upgrade your Orbi mesh network system (Ensure to upgrade the satellite before the router. Upgrading the router first may create compatibility issues due to interim periods of being on different firmware.):
- https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
Community Team
- JeffinDallasOct 06, 2025Aspirant
I've updated to the latest firmware and am stilling seeing degraded speeds compared to speeds at the Modem. Any other ideas?
- FURRYe38Oct 06, 2025Guru - Experienced User
Ethernet speeds good or no?
Factory reset and setup from scratch?
