AmCovi2021
Sep 23, 2021Follower
RBR850 v4.6.3.16_2.0.51 constant disconnect and reconnect
Woke up to a solid magenta light on my Orbi. I updated the firmware and have restarted it twice. The orbi connects to the internet and I have a good WiFi signal then it drops back off. My wired connection is still functioning properly. I work from home and need both the WiFi and wired connections to work. Any advice would be greatly appreciated.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- SedulityGuide
I am having the same issue. Havent run into any problems in the last 30 days. RBR850 is in AP mode, router is currently online. It is strange that the issue is only occuring for this device while the orbi is put into AP mode (which is required for my current internet setup). I have only had this problem since the last automatic update (Running (4.6.3.16_2.0.51) as well).
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
- SedulityGuide
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Sedulity wrote:I am having the same issue. Havent run into any problems in the last 30 days. RBR850 is in AP mode, router is currently online. It is strange that the issue is only occuring for this device while the orbi is put into AP mode (which is required for my current internet setup). I have only had this problem since the last automatic update (Running (4.6.3.16_2.0.51) as well).
Yes, multiple factory resets were already performed this morning. After the resets the issues persisted only while the RBR850 devices were in AP mode. Logging in and switching back to router mode fixed the constant disconnects from all other appliances. I would like to restore my network to its original configuration where the RBR850 is in AP mode. No changes were made to upstream appliances and there also weren't any updates pushed to them. I have kept the same network configuration with the Orbi devices for the last ~1-2 years so it seems a little odd my work from home setup gets broken from 1 update.
- RC-RCAspirant
how did you fix the problem? i still have the same problem. I have tride a factory reset, restart etc. but nothing is working?
FYI, @ netgear hasn't log into there profile account since 2015 so probably no use in tagging them. If you want to tag someone, try a forum moderator like @ blanca_o or @ darrenM
What I did to get v4.6.3.16 working on 8 series:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2155645/highlight/true#M22357
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-Online-Update-4-6-3-16-RBR850-RBS850/m-p/2154700/highlight/true#M22256New Orbi v4 Factory Reset:
You may need to factory reset the system and power the system OFF as well.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150287/highlight/true#M21560
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150391/highlight/true#M21575
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4-6-3-16-Released/m-p/2150417/highlight/true#M21579
RC-RC wrote:
netgear when do you release a firmware update where the problem is fixed? timelins please!
Setup: 1 x RBR850 -> 2 x wired RBS850
Any progress on this?
