udpumpkin's avatar
udpumpkin
RBRE960 Losing Internet Connectivity
I have a new Orbi wi-fi system connected to an AT&T fiber modem/router.  I have the Orbi set to bridge (AP) mode.  I have wi-fi turned off on the AT&T router.  I have an ethernet cable going from the AT&T router to the Orbi.  Then I have hardwired cables going from the Orbi router to two satellites.  I also have an ethernet cable going from the orbi to an ethernet switch and out to devices.
Every couple of days, I will lose internet.  Today, I lost internet on a wired desktop, a wireless laptop and my cellphone.  At the same time, a wired desktop, wireless security cameras, and wireless Google home devices were still on-line.  Over the next hour, devices started losing internet connection until finally nothing could connect to the internet.  Wireless devices would say my network was not connected to the internet.  I power cycled just the Orbi and it did not restore an internet connection.  I power cycled the AT&T modem and everything started working again.  The AT&T modem before I powered it off and on indicated that it had an internet connection.
Is this likely a problem with AT&T, Orbi or could be either one?  Before I bought the Orbi system in March, I had an amplifi mesh network and got tired of restarting it when devices couldn't connect.  I have just lived with the Orbi issues since they happen occasionally.  But it is starting to get annoying.
Any troubleshooting advice would be much appreciated!  I know this is probably a common issue that can have a bunch of different causes.  I probably should have contacted Netgear in the first 90 days to troubleshoot when support was still an option.
Thanks!
Router firmware: v6.0.3.85
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Does the Front LED on the RBR or RBS how any indication of problems?
    Be sure you have the ISP check there services to the modem. Signal and line quality.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    How are the RBS connected to the RBR? Directly to the RBR or is there a LAN switch in between? Brand and model of LAN switch.
    Are you using the 2.5Gb LAN ports or the 1Gb LAN ports to connect the RBS to the RBR via ethernet?
    What CAT# lan cable are you using here?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Do you have the IoT and separate 6Ghz SSID broadcast running?
    • udpumpkin's avatar
      udpumpkin
      Thanks for the reply.
      The model of modem/router from the ISP is a Pace 5268AC.
      Our home is single story and ~2,000 sq ft in kind of a triangle shape.  We have the router at one corner and the satellites hardwired with cat6 cable at the other points of the triangle.  The signal shows up strong on all of our wifi devices.  The house is hold with plaster walls and no insulation.
      The satellites are connected directly to the router with the cat6 cable.  There is only one 2.5Gb port on the router and one of the satellites is connected to it with cat6.  The other satellite is in an ethernet port which is probably 1 Gb.  The switch is a Netgear GS308.  It is connected to the router and devices other than the satellites are connected through the switch (computers, tv streaming box, etc.).
      The settings are 2.4 Ghz auto, 5 Ghz 48, 6 Ghz 69
      I do have the IoT network enabled but don't have anything connected to it.  I do not have the 6 Ghz enabled.
      There are competing wifi networks 3-4 but Orbi shows "Good" or "Great" on every channel in the app.
      The orbi router will show a magenta light when it has lost internet.  However, not all devices will lose internet at the same time.  Right now the light on the router is magenta.  My phone does not have internet from wifi.  But the computer I am using that is connected to the satellite which is connected to the router by wire is fine.  The google home device on my desk that is wifi still has internet.  If history is a guide, eventually every device wired or unwired will lose internet and I will need to power cycle everything.
      • FURRYe38's avatar
        Well PINK on the RBR means that the RBR isn't getting good internet services from the ISP Modem or there is a problem with cabling between the modem and RBR.
        For the size of home, only the RBR and maybe 1 RBS would be needed.
        Have you tried bridging the modem and running the RBR in router mode?
        What is the CAT# lan cable your using between the modem and RBR? CAT6 is recommended.
        I would disable IoT network if your not using it.
