HoraceChan's avatar
HoraceChan
RBS850 out of sync backhaul
Hello All, i recently bought a new RBS850 Satellite-2 below and connect to my current RBR/RBS Sat 1 mesh. However the backhaul status of the new RBS850 Sat-2 is always out of sync and no devices could connect to it. Moreover when i try to access its login page to see the status, i can go in but it is always looping without and status return to my browser. Anyone could help me with my problem please? the firmware version is v4.6.3.16 across them. thanks a lot!
Check for new version from the Internet.Check
Status:
  Model Name Device Name Current Firmware Version Status
RouterRBR850RBR850V4.6.3.16No New Firmware Available
SatelliteRBS850Orbi Satellite-1V4.6.3.16No New Firmware Available
SatelliteRBS850Orbi Satellite-2V4.6.3.16No New Firmware Available
UpdateAll
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Try connecting the one RBS to the back of the RBR via ethernet cable and see. Turn off the other working RBS.
    You might review this as well:
    https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-v4-6-7-13-Official-Release/m-p/2202301/highlight/true#M29425
    • HoraceChan's avatar
      HoraceChan
      Thanks a lot for quick response and much appreciated FURRYe38.
      HC> Not sure
      HC> 1000 sq feet. 4 rooms with thick concrete walls
      HC>Now it is 10 feet. I tried to put it in a number of places within my home but still failed. i.e. backhaul status out of sync and no device can connect except via ethernet directly
      HC>Will try tomorrow.
      The ORBI mobile app shows it as "green" but no device connected to it. Again is this new one faulty as i login its admin page but always looping for status update?
      Should i try to upgrade the firmware of all ORBI first? but if i cannot access the new one how can i upgrade its firmware?
      Thanks again!
      • FURRYe38's avatar
        IF you can get the RBS connected to the RBR via ethernet, update the RBS using its' web page. Update the other RBS as well. If you can get the RBS updated with FW, then update the RBR lastly.
