Re: Orbi RBR350 + 2 satellites internet speed question
Hi!
Actually, I have one last question for you, because now that I think of it, it's not clear on my part:
Does the second RBS satellite communicates with the first RBS satellite? Or does it communicate only with the RBR?
Thanks!
  • FURRYe38's avatar
    For backhaul, depending of the RBS is in star formation, the RBS would connect to the RBR. If the RBR and RBS are in a daisy chain configuration, then the RBS would connect to the nearest RBS that is closer to the RBR.
    When you give the power line adapter configuration a try, then the RBS wil connect to the RBR if you connect the PL adapter behind the RBR and then the other adapter to the RBS.
    • StephenB's avatar
      maxpuissant​: Before you connect the RBS to the adapter, you should first connect your laptop and run a speedtest.  It's important to use the same outlet pair for the adapter that you plan to use with the RBS.
  • StephenB's avatar
    The backhaul itself can either go directly from the second RBS<->RBR or it can be daisy-chained (RBS<->RBS<->RBR).  The web ui should tell you which topology you have.
    As far as control goes, AFAIK Netgear has never disclosed the details.
      • maxpuissant's avatar
        maxpuissant
        Guide
        Oh ok, I'm using the Orbi app and it's show a straight line crossing the RBR and both RBS. So I guess it means that the second RBS is using the first one. Thanks.
