Rob1988's avatar
Rob1988
Regular Guest WiFi Drops
I just purchased RBR750 w/ 1 RBS750. Ran into the exact issue with guest WiFi. I manually updated the firmware to V4.6.8.5_2.1.9 but the issue is still ongoing with guest network only.
I have tried every suggestion found in the forums with no change. Now finding this thread I am not optimistic the issue will ever be resolved considering it has been ongoing for at least year at this point. The old router never dropped guest WiFi was after more coverage is why I changed to Netgear mesh network
    This was fixed for others and me since the last firmware. It's still fixed for the (new/lat)est firmware too.
    • Rob1988's avatar
      Rob1988
      I have monitored since last post. I have 4.6.9.11 firmware. Seems more prone on Android type devices. Kindle fire 10 every few hours. Android phones more than iPhone no pattern. IOT devices are stable. Parental Control Off. Armor On but tried turning off, no change.
      • ekhalil's avatar
        ekhalil
        Master
        1. Are also the satellites on v4.6.9.11?
        2. Do you have the same security settings in the guest network as the main network (e.g. WPA2-PSK,...)?
  • CrimpOn's avatar
    CrimpOn
    Sorry to be just now joining the discussion.  Perhaps it is obvious to everyone what the exact issue is, but not to me.
    Could you please describe the problem in more detail?
    Thanks
  • FURRYe38's avatar
    How often are these disconnects with the guests devices seen?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a factory reset and setup from scratch been performed with out enabling any Armor or SPC?
  • iyang's avatar
    iyang
    NETGEAR Expert
    Hi Rob1988 ,
    Does Android phone connected Base(RBR750) or Satellite(RBS750) ?
    How satellite connect to base via wireless or wired ?
    Thanks.
