FilGov
Jan 24, 2021Aspirant
Satellite stopped doing 2.4 GHz
1 of my 2 RBS850 satellites suddenly stopped accepting 2.4 GHz connections, only 5 GHz works.
What 2.4Ghz devices are you using?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- FilGovAspirant
Mostly Rowenta Intense Pure Air Connect XL air purifiers and TP-Link HS110 smart Wi-Fi plugs.
V3.2.16.22_1.4.9.
MEO FiberGateway GR241AG.
~271 m2.
~5 m.
Auto. Yes. Done, issue persists.
Yes. 1.
FilGov wrote:Mostly Rowenta Intense Pure Air Connect XL air purifiers and TP-Link HS110 smart Wi-Fi plugs.
V3.2.16.22_1.4.9.
Your ONT has built in router and wifi already.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop~271 m2.
~5 m.
Yes. 1.
