jfer3351's avatar
jfer3351
Separate IoT WiFi network available in Orbi RBK853?
Dear Netgear community,
Does the Orbi RBK853 provide a separate IoT WiFi network operating exclusively in the 2.4 GHz band?
The RBK853 user manual suggests that a separate IoT WiFi network in the 2.4 GHz band does exist; however, there are a few posts in the Netgear community that suggest otherwise.
Could any RBK853 users please clarify this? Thank you very much!
Link to RBR850 user manual (see pages 57-60 for IoT WiFi network): https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
Link to post suggesting that this feature does *not* exist in RBR850: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/RBK853-IOT-network-not-present-in-Wireless-settings/m-p/2279653
  • Not at this time. FYI, be on the look out for next FW update. All I can say.
  • FURRYe38's avatar
    • jfer3351's avatar
      jfer3351
      Many thanks for the quick answer!
      Any idea about the release date for this FW update? I need a dedicated IoT network in the 2.4 GHz band rather urgently and, at the moment, my only option in the Orbi ecosystem is the pricey RBKE963.
      Thank you.
