Oct 12, 2023Guru - Experienced User
Share your Orbi 350, 750, 850 or 960 series system UpTime
Found on the routers and RBS IP address/debug.htm web page for best details, please post both RBR and RBS uptime. Please note of any inconsistencies between the RBR and RBS. Generally the RBR and RBS uptime should be same. Home wide power brown outs should be noted if these are seen.
Thank you.
- spewakLuminary
RBR 850:
Basic Information
Firmware Version: V7.2.6.21_5.0.20
Boot Loader Version: V1.0.13
seal: v2.1.5.49-0
seal_services: v2.1.5.20-0
armor-bd: v2.2.100.3
spc-circle: v3.31.1.2
CPU Load: 11.27%
Memory Usage(Used/Total): 446 MB/874 MB
System Uptime: 28 days 20:54:06
RBS850 #1:
Basic InformationFirmware Version :V7.2.6.21CPU Load :13.7%Memory Usuage(Used/Total) :325 MB/874 MBSystem Uptime :34 days 21:38:32Hop Count :RBS850 #2:Basic InformationFirmware Version :V7.2.6.21CPU Load :7.11%Memory Usuage(Used/Total) :800 MB/874 MBSystem Uptime :34 days 21:42:16Hop Count :1- claudiutApprenticeRBR 750:
Basic Information
Boot Loader Version: V1.0.14
seal: v2.1.5.49-0
CPU Load: 29.73%
Memory Usage(Used/Total): 353 MB/874 MB
System Uptime: 16 days 06:29:35
RBS 750:
Basic Information
Firmware Version : V7.2.6.21
CPU Load : 17.01%
Memory Usuage(Used/Total) : 305 MB/874 MB
System Uptime : 16 days 6:34:47
Hop Count : 1- FURRYe38Guru - Experienced User
RBK963 System
Basic Information
Firmware Version: V7.2.6.21_5.0.20Boot Loader Version: 2016.01_rtm-5.0.1.32
seal: v2.1.5.49-0
CPU Load: 14.13%
Memory Usage(Used/Total): 369 MB/818 MB
System Uptime: 7 days 00:15:31
Anyone with 960 series Orbi systems out there, could you please post the CPU, Memory usage and system uptime from the RBRs IP address/debug.htm web page please?
Will be hitting 30 days of good uptime on my RBK853 system with v.15 FW loaded. Been good and solid.
I can't say anything about IPv6 as my ISP doesn't support it natively so I can help there.Otherwise, been good for me.
Anyone else have good up time on this version of FW?
31 plus up days on this version of FW for the 854 series. Working good.
Off to check on a different system now.
Posting this here to start a base line for my RBKE963 series running latest v.15 FW
RBR:
Firmware Version: V7.2.7.15_5.1.16
seal: v2.1.10.12-0
armor-bd: v2.2.214.4
spc-circle: v3.32.0.4
guster: v1.0.0.2049
CPU Load: 6.78%
Memory Usage(Used/Total): 393 MB/818 MB
System Uptime: 5 days 00:12:46
RBS-DR:
Firmware Version :V7.2.7.15
CPU Load :13.18%
Memory Usuage(Used/Total) :365 MB/812 MB
System Uptime :5 days 0:25:32
Hop Count :1
RBS-BM:
Firmware Version :V9.12.5.3
CPU Load :11.49%
Memory Usage(Used/Total) :602 MB/1743 MB
System Uptime :1 days 2:59:50
Hop Count :1
Bootloader Version :U-Boot 2016.01_rtm-9.6.0.2 (May 27 2023 - 00:22:49 +0000)
I see this RBS has mysteriously rebooted something yesterday. Not sure why. Only have a LAN switch connected and one Xbox Series X connected to this switch that is behind the RBS.
I just remembered, I was getting a different system online staged while the 963 series was already online. I had 3 systems running for a short time while I put one system online and the out going system was waiting to be turned off. This time frame around the time the RBS960 seems to have rebooted, maybe encountering some interferences as for the time I had 3 systems online was for about 5-10 minutes then after turning off the 3rd system, was back to two systems. I'll probably chalk this up to some noise going around the.
Both RBS are wireless BH.
Keep monitoring.
- Retired_Member
RBKE963 Basic Information
Boot Loader Version: 2016.01_rtm-6.0.2.21
seal: v2.1.10.12-0
guster: v1.0.0.2049
CPU Load: 7.18%
Memory Usage(Used/Total): 429 MB/818 MB
System Uptime: 35 days 12:58:02
Now at 10 plus days of good up time on the 963 series:
RBS1:
RBS2:
RBS wirelessly connected to RBR.
Solid operation with v.15 FW.
- jmvtevAspirant
950 flashed with 960 firmware. I have had it about a year and a half. Had been working great up until about 4 months ago. I have 3 wired ( CAT 6A ) mesh satellites and about 120 clients. It is supposed to handle 200+. This may explain my high cpu usage. Lately it will not go a couple of days without it rebooting itself or becoming very unstable. Hoping they release an update to the firmware so I don't have to throw it out.
Do you have additional features enabled like Armor, Access Controls, Guest Network, IPv6, SPC, and Traffic Meter?
Might do a full on factory reset and set up from scratch and see if the CPU usage comes down. Thats too high. You may burn out the RBR. I'd get a cooling fan under the CBR unit.
Might test and reduce the amount of devices connected to see if CPU usage reduces.
What prior FW version was loaded on it?
- jmvtevAspirant
Only guest network is active. I had 7.2.6.31 prior to this and did experience some problems with it. I went from the 950 firmware to the 960 firmware because I kept having issues with the 950 firmware. I will try a fan as you suggested. If it doesn't help then I will do the full reset as a last resort. With so many clients it is kind of a pain doing the full reset. Thanks you for the suggestions.
- Retired_Member
RBRE960:
Basic Information
Firmware Version: V7.2.7.15_5.1.16Boot Loader Version: 2016.01_rtm-6.0.2.21
seal: v2.1.10.12-0
guster: v1.0.0.2049
CPU Load: 7.24%
Memory Usage(Used/Total): 442 MB/818 MB
System Uptime: 46 days 23:01:55
RBSE960 - 1
Basic Information
Firmware Version :
V7.2.7.15
CPU Load :
16.19%
373 MB/812 MB
System Uptime :
46 days 23:1:16
Hop Count :
1RBSE960 - 2
Basic Information
Firmware Version :
V7.2.7.15
CPU Load :
16.01%
375 MB/812 MB
System Uptime :
46 days 23:1:3
Hop Count :
1
