JediofNorth
Jun 20, 2022Aspirant
Slow Download Speed RBK853 Firmware 4.6.3.16
I have buy a rbk853 1month ago. When i has set up and do some speed test by wired i has got like 850down and 700 up all was good. For 1.5giga fiber. The problem is today i got only 65down but the upl...
Jun 20, 2022Guru - Experienced User
Are you speed testing wired or wireless? Wired is preferred.
What devices do you have connected?
Make sure your ISP modem has a 2.5Gb speed port on the ISP modem/ ONT.
JediofNorth
Yeah i do it by wired. I has do it by wireless too and I got the same result for the download speed. Only My Computer. 2cellphone and a tv. But when i speed test it Only my Computer and 1cellphone is use. No worries is connect on a 10gbport.
Size. I has put the router in my entry. Put the sattelite in my chamber. I live in a 5 1/2 appartement. Yeah more than 30feet. But i dont think 2feet or 30feet is the reason when i use wired connection.
When i has buy it The download was really good the upload too.
Presently the download never go up more than 65mbs... I have change nothing. Is it just some inconsistance about the router/satellite? Like maybe next week i gonna rehave my good download?
Is work by satellite. The rain outside can be a problem? If have rain like 3-4day this week? I can share you when i have buy i got 850 in download. Presently 65. I have switch nothing.
