pco614's avatar
pco614
Tutor
Mar 11, 2026
The RBS will not go to solid white
I'm having the same problem, only to add frustration, the RBS will not go to solid white, after reset connected to computer via ethernet with RBR turned off, it flashes white for a while, and then glows solid pink.  I've done all variables of the reset process.  At one point earlier I was actually inside the RBS and tried to update, but it said update failed! I used downloaded firmware file
RBS750-V7.2.8.5.chk. Any ideas would be very appreciated, I don't just want to throw out my two satellites!
  • Hi All, I just wanted to say that I fixed the problem.  I went back to the most recent previous firmware version on the router, and although the satellites were out of sync, they were recognized. I matched the firmware to the router version and all is fine.  I can now do the new update ( doing the satellites first this time...)  Thanks again.
  • plemans's avatar
    There was a set of orbis that had a rbs350 with them. there's also the RBS760. I'd be curious to ensure you had the correct model for the update. While you're logged into it, check the version you're on and post it here.
    Also, what firmware version is the router on?
    • pco614's avatar
      pco614
      Tutor
      Hello all, thanks for responding.  The RBR and RBS750 is the correct model. I received an email from Netgear notifying of the need for an update: "Our records indicate that your Orbi AX4200 WiFi 6 High-Performance Router(RBR750) has an older firmware version installed that might prevent your device from auto-updating." And yes, I did make the seemingly fatal error of updating the router first.  I'm attaching a pic of the router info. The "solid white" mentioned above was from another help page.
      • pco614's avatar
        pco614
        Tutor
        Sorry, can't seem to load jpg, here's the info:
        Router Information
        Hardware VersionRBR750
        Firmware VersionV7.2.8.5_5.1.21
        GUI Language VersionV3.0.3.12_2.1.30.3
        Protection Engine Version2.2.214.4/1.0.0.2049
        Operation ModeRouter
        LAN Port
        MAC AddressC8:9E:43:C8:A4:BE
        IP Address192.168.1.1
        DHCPOn
