John--B
Apr 19, 2025Star
Updated firmware to 7.2.7.15 on a RBR750 and 2 RBS750's
I now have one of my RBS750's reporting as model RBS750QV and reporting that the status "update failed". Current name and current firmware version are correct and show firmware as 7.2.7.15 and three devices are currently connected to the RBS750QV. Anyone know what is wrong?
- KnightWareInitiate
Same here RBS750QV update status failed. Checking for new firmware under 7.2.1.5 says nothing new. However, Net Gear site says it's 7.2.8.5 for the RBR750 and RBS750. I disabled auto update and downloaded/manually updated both satellite first, then the router. The router name reversed back to RBR750 and both updates successful (No update failure on RBS750.
Glad to hear this and glad the RBS reverted back to corrected operation.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
I updated my devices a couple of days ago to firmware 7.2.8.5 and all devices are working fine. Satellites are named correctly as RBS750. New firmware has corrected this issue. Thank you!
Good to hear. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
