GOSPDRCR57
Jul 31, 2022Aspirant
Using CBR750 with WPA3 as a bridge for WPA2 printer
I can't believe I have to post on this forum instead of getting proper instruction with somebody from netgear but here we go...
I have a CBR750 mesh system with WPA3 enabled, my printer i just bought only accepts WPA2, is there a way this router can act as a wireless bridge or access point for that one item so I dont have to go into my setting and switch to WPA2 just to print a few pages? If I'm on my wireless devices I could switch to the guest network which i have setup on WPA2 but I dont have that option for my wired desktop. I know WPA3 and WPA2 cant communicate with each other, any help would be greatly appreciated.
You'll need to set WPA2 mode on the CBR if you want the printer to connect.
- GOSPDRCR57Aspirant
but the whole of point of choosing this router was for the wpa3/wifi6 capability running it in limp mode seems counterintuitive, could it be done with a rasperry pi and a printer server?
Something to ask the printer Mfr about. It's there product that doesn't support WPA3. It needs WPA2 or try ethernet if the printer supports that.
Does WPA matter if it's plugged directly into a satellite via ethernet? Thats how i have it setup now, and I can see the printer on orbilogin but the printer is still telling me its offline
No. I would connect the printer to the RBR via ethernet. Then try to connect to it.
