nerdfrenzy
Jul 23, 2025Aspirant
What information is restored on RBR850 when restoring from backup
Hi, If I backup my Orbi RBR850 and then do a factory reset, what configuration information will be restored to my system when I restore my backup. I can't find anything to say that all my DHCP r...
- Jul 23, 2025
Yes, when a backup configuration is loaded, everything returns.
WiFi credentials (SSID/password)
LAN Setup (IP assignments)
Channel assignments
OpenVPN configuration
.... everything.
nerdfrenzy
Jul 24, 2025Aspirant
Thanks.
I wanted to be sure as I need to update my firmware and every time I do it it my Orbi continually drops connection to my ISP around every 24 hours and I have to reboot it to get things working again. This has been happening since the the 7.2.x firmware has been released so I'm currently running on 4.6.14.3_2.3.12 which has been stable but is missing all the latest security fixes.
I will give it a go
Jul 25, 2025Guru - Experienced User
Please review this to manually update a Orbi system, works well:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
For any odd issues seen after a FW update, please try a factory reset to see if this resolves issues first:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
nerdfrenzy wrote:I wanted to be sure as I need to update my firmware and every time I do it it my Orbi continually drops connection to my ISP around every 24 hours and I have to reboot it to get things working again. This has been happening since the the 7.2.x firmware has been released so I'm currently running on 4.6.14.3_2.3.12 which has been stable but is missing all the latest security fixes.
I will give it a go
