jhey
Apr 27, 2026Aspirant
771 mesh router and satellite - no seamless transitions
I have the 77X mesh router and satellites, and whenever I move from upstairs (where the main router is) to ground floor (satellite location), my phone ‘s wifi disconnects and takes a long time to reconnect (I often just forget the network and reconnect with password, otherwise it takes more than 5 mins). I have the latest firmware and this issue has existed for a long time and was hoping that latest firmware would fix it permanently, but so far no luck.
I never had this issue with an older wifi 5 mesh from Orbi, but this wifi 7 mesh has been consistently VERY unreliable.
- jheyAspirant
iPhone 15 Pro
How big is the home? How many satellites? How many levels?
Could be that the phones built in roaming protocol doesn't call for them to switch to a stronger signal yet. If the older AC tech didn't broadcast as far, they might not roam as often with a newer/faster system.
- jheyAspirant
2600sqrf , two satellites, basement, ground, upper level.
What is the distance between the router 📡 and satellite(s)🛰️
For that size of home, the RBR and just one should work well.
Can you try to see if turning OFF one RBS results is same tranisition issues?
- jheyAspirant
Yes, same locations. Yes, that’s the firmware version that I have. Yes, happens with other mobile phones.
Which phone platform are you using? Apple or Android?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 Enabled or disabled?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home: NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Try disabling the following and see: Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
