Sagnew's avatar
Sagnew
Apprentice
Oct 10, 2023
970's 6E Broadcast Issues. Router vs Satellite
Hi! Quick question. Seems some folks are having similar issues with posts in other forums.
970 Router and satellite are up and running. Speed test looks great. When I am in the room with the satellite I maintain a 6E connection no issues. However if I move to the room right next to where the main 970 router / base is located, I lose that 6E and I frequently drop the connection / have to manually reconnect.
I am using a Samsung ultra 23 phone.
Any ideas why the main router would not broadcast 6E whole standing next to it? Is my satellite potentially canceling our my routers signal ?
  • FURRYe38's avatar
    Building materials are a factor in how wifi travels and can inhibit wifi signals. The signal seen by the phone and quality will cause the phone to change connections from 6Ghz to something else. It's up to the phone to make the determination of signal quality and if it needs to switch.
    Also the phone may connect to a more distance RBS as well and keep connected even if you move around closer to the RBR until it's finally decides to change the connection to the better signal of your force it by disabling the phones wifi radio for 5 seconds then back ON.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    How many RBS are deployed?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    • Sagnew's avatar
      Sagnew
      Apprentice
      https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
      Thank you! While standing in front of the main router / base and changing this setting on my Android phone, it instantly reconnected as 6E. First 6E connection I have had in this room since the initial install. Hoping it remains this way. I am guessing my phone is holding onto / prioritizing the 6E satellite connection in that other room over the main base/router? Details are below...
      1 Satellite / 1 Router
      1600 sq feet. Single story (+ another 200-300 with front and back yards). Router placed towards back of house. Satellite towards front of house. Older home, previously no connection or dropout issues with my previous Orbi 850s and the  "regular" Wifi6 connection. 6E makes a substantial speed difference for me. When connected to 6E, I get 1.2gb/s on my phone via wifi. When it's "regular" 6, that drops down to 400mb/s.
      About 45-50 feet. There is a clear path via a hallway to that other room. Live in a relatively busy area, with lots of routers / wifi traffic, which is why Wifi 7/ 6E was appealing. Typically can see 10+ other wifi network connections in our living room
      • FURRYe38's avatar
        For that size of home, 1600sq ft maybe to small to have a RBS. One thing I wish NG would bring back and hope they do, is power adjustments. Having this helps with a smaller size home and having too much wifi signal in a small space with having additional RBS deployed.
        Hopefully you'll be ok for now.
  • FURRYe38's avatar
    When this happens can you log in to the RBRs web page to see if the RBS are showing a GOOD status or anything different? Like Config Sync.
    Also can you log into the RBR and the RBS debug page and copy and paste the upper data section of these page here as well? RBR or RBS IP Address/debug.htm
    • Sagnew's avatar
      Sagnew
      Apprentice
      Ack! I just received the beta firmware last evening...But if/when that happens again - I'll paste logs.
      This was ONLY happening when connected to the router itself. Zero satellite connection issues
      • FURRYe38's avatar
        Ok. Interesting. Thanks for the feedback.
        Monitor this now that you have the beta and see how it goes.
        Keep us posted.
  • FURRYe38's avatar
    Any progress on this?
    • Sagnew's avatar
      Sagnew
      Apprentice
      Fwiw, since upgrading to a phone that now supports Wifi 7, I have had zero connection issues along with outrageous speeds. That may be due to the nature of Wifi 7 (using both 6 and 5ghz channels) vs just Wifi 6.
      My wife is still having connection issues with her Apple products which are limited to Wifi 6.
      But quite pleased and happy with Wifi 7 and excited for more devices to roll out with Wifi 7 connectivity.
      • FURRYe38's avatar
        Thanks for letting us know. Hoping next FW update will be better for everyone.
