TOPS119's avatar
TOPS119
Luminary
Jan 28, 2024
After the update my iPhone 15 pro max stop showing correct speed
Well as I stated above my iPhone 15 pro max stop showing the correct speed on the speed test. I have about 250mbps connection @ home , it now only shows 64mbps, on the Mac it shows the full 250mbps in the same area, it almost got me in trouble with the isp as I called them thinking I wasn't getting the correct speed. Anybody else has this issue ? it start happening after the new force update.
  • FURRYe38's avatar
    Has the the Orbi system been powered OFF for 1 minute then back ON since after the FW update?
    Is Protected WiFi IP address enabled on the iPhone?
    What iOS is on the iPhone?
    • TOPS119's avatar
      TOPS119
      Luminary
      Yes orbi was restarted for the 1min
      Private wi-fi address is on
      its on the latest os
      • FURRYe38's avatar
        Restarted or Powered OFF then back ON after 1 minute?
        Does this still happen if you disabled Private WiFi address feature on the phone?
        There a version number of the iOS on the phone?
