CAL-GB's avatar
CAL-GB
Tutor
Jun 15, 2026
Frequent drops, crashes, and network noise…how I fixed it
For about a year and a half, I dealt with frequent drops on my Orbi system. A couple months ago, I got serious. Drops were daily, sometimes multiple times. I have about 150 devices, mostly Lumary recessed lights. Cool, but noisy. I’m replacing them with Hue lights for their bridge. I use Kasa switches, but I’m switching to Lutron Caseta with a bridge, plugging into a satellite. The USB-powered fans I found on Amazon fit like a glove on the router and satellites—almost as if made for them. With the fan, temps dropped from 100°F to 75-80°F. The last 24 hours—no drops. Crashes used to happen when everyone streamed; now stable. I’ll add these $15 fans to satellites too. With Hue and Lutron bridges, I’m hoping to clean up network noise even more!
  • FURRYe38's avatar
    Have heard of many IoT smart bulbs causing problems for wireless systems over the years.
    Having that many devices as well, I guess would be problematic for sure.
    Which fan did you find for the 970 series?
    Definitely use a fan on top of my RBR971. I always recommend a fan on top or under any router. Been using external cooling for years now. Saves the hardware from heat damage over the life.
    • CAL-GB's avatar
      CAL-GB
      Tutor
      https://www.amazon.com/dp/B07R659J8Z?ref=ppx_yo2ov_dt_b_fed_asin_title
      • FURRYe38's avatar
        Kewl, Will keep this on my fan recommendation list. I have something similar but with rubber feet. They work great to keep these cooler.
        Glad you found the fix.
        Be sure to save off a backup configuration to file for safe keeping. Saves time if a factory reset is needed.
        Enjoy.
