AbbasRaza's avatar
Nov 14, 2023
I am currently on IOT network with my pixel 8 pro
Can you tell us when will you guys release the firmware. I am currently on IOT network with my pixel 8 pro.
  • Did you get a beta version from NG that was working? If you had then updated over that, then you might have re-introduced the problem. If you have the beta version from NG, you'll need to apply it back ON again to the RBR. You'll also need to disable Auto Update as well on the RBR first.
  • Straq's avatar
    Straq
    NETGEAR Expert
    Hi there,
    Engineering team here. It will be about a few weeks before FW release. I will be messaging directly if you will like to receive FW earlier.
  • plemans's avatar
    why are you on the IoT network?
    It won't connect to the primary network?
    what version of android is on the pixel pro 8?
    Reason I ask is my Moto Edge+ 2023 only connects to wpa2 and has issues with mixed wpa2/wpa3 on Wifi 7.
    Supposed to be an update someint with android 14 that fixes the issue but I have it on both my RBE973s and an Arris G54 (wifi 7)
    • AbbasRaza's avatar
      AbbasRaza
      Guide
      It's because of the pixel 8 pro. If I connect to the primary SSID the orbi just randomly reboots itself. Every time. It's a known issue and Netgear team is aware of this. Please see above comments from the engineering team. They are trying to fix this issue with a firmware update. For some reason it works perfect on the IoT network. I have it set to 2.4 GHz Wi-Fi only.
      • FURRYe38's avatar
        FYI, another user mentioned putting there Pixel devices in the IoT network and it solved the issue as a work around. Yes, NG is aware of it and does have a fix there testing. I believe you can get the fix from Straq
        Please send him a private message and check on this.
