crowe2024
Sep 22, 2024Tutor
Orbi 770 Mesh devices drop wifi | Wired never drops
I have a 3000 sqft multilevel home, two new 770 Orbi Mesh devices. I have an Orbit on first floor and an Orbit on second at the far end.
When in my bedroom which is in between the two devices, my laptop and phone will go from full signal, drop a bar, then the wifi completely drops from the device to come back a few seconds later with full signal.
This makes me feel like the Orbi is waiting too long before letting the device roam to the better AP from a signal standpoint.
These devices are using 5/6ghz, I have reset my router and satellite and ran setup a second time, updated to the latest firmware, but nothing seems to help and I'm not past my return window.
Support was not able to give me anything else to change/try past what I have done.
This is purely wifi signal completely dropping, my wired ISP connection never drops, even if it did the wifi signal would stay the same but with no route to internet.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Where is the Orbi RBR located?
Where is the Orbi RBS located?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Any Wifi Neighbors near by? If so, how many? - FURRYe38Guru - Experienced User
Any progress on this?
Hello and apologies I have not replied, I began working with Netgear support and they have been keeping me busy capturing logs among other testing.
Where is the Orbi RBR located? MIDDLE OF FIRST FLOOR ON A TABLE
Where is the Orbi RBS located? SECOND FLOOR FURTHEREST BEDROOM
What is the size of your home? Sq Ft? 3000 sqft
What is the distance between the router 35-40FT +
Does this happen with the RBS turned OFF? YES
I live in a builder style multi-level home, built in 2015. Mostly open floor plans with minimal walls.
I have tried different locations, I removed my firewalla firewall and have connected the RBR directly to the modem with a new CAT 8 ethernet cable.
I have changed channel for 2.4 as well as the 5ghz, there is not an option to make any 6ghz changes in the orbi.login page.
I purchased another satellite and use it instead of my original, also tried using it as a 2nd RBS for coverage just in case.... Still same drops on laptops, mobiles, tvs. Drops out and within a few seconds reconnects.
I feel like at this time, the issue is isolated to the RBR and I am pushing netgear to allow a warranty claim as it is just over 30 days from purchase date.
I do have a house on each side of me, so that is two homes with wireless as well. I have tried changing channels multiple times in case there is co-channel interference but no progress.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite - FURRYe38Guru - Experienced User
If this happens with just the RBR ON alone, possible some issue with the RBR.
