manusjuhl
Sep 28, 2026Guide
Orbi 772 backhaul through MoCa
Hi everyone,
I hope someone can help point me in the right direction, because both I (and Copilot, Gemini, and ChatGPT) have run out of ideas.
I recently purchased a new mesh system (Netgear Orbi 772) consisting of one router and one satellite.
My internet connection is delivered to the house via fiber, and I want to distribute it through my existing coax cabling (TV antenna cables and outlets throughout the house).
My setup is as follows:
Fiber Modem
TP-Link AC1200 Router
goCoax MoCA Adapter
5-2400 MHz 6-port coax splitter
goCoax MoCA Adapter (Room 1) → Orbi Router
goCoax MoCA Adapter (Room 2) → Orbi Satellite
The coax network is only being used to carry internet traffic.
The main Orbi router works perfectly, but the satellite keeps showing as "Disconnected".
It's worth mentioning that the router and satellite are too far apart to communicate wirelessly, so they must use the coax/MoCA network for backhaul.
Additional information:
- Wi-Fi is disabled on the TP-Link router.
- The Orbi system is running in AP Mode.
- Both goCoax adapters show the expected MoCA link LEDs.
- I have swapped:
- Both Orbi units
- All three goCoax adapters
- Ethernet cables
- Coax ports/locations
- If I place the router and satellite in the same room and connect them directly via Ethernet, the satellite immediately comes online with a Wired/Good status.
- If I move the satellite back to the remote room and connect it through the MoCA network, it becomes Disconnected again.
From my perspective, everything is connected correctly, but I clearly seem to be missing something.
Has anyone experienced a similar issue with Orbi + MoCA or have any suggestions on what I should investigate next?
Thanks in advance for any advice! 😊
Anytime I see 6x splitters, I get a bit nervous. Most of them you see, aren't powered so they have significant signal reduction because its split. And if they are powered, not all of them are decent and can still corrupt the signal. I'd start with just going moca--->moca without an adapter/splitter. Run 1 of the orbi's off that and see if they backhaul stays stable. IF it doesn, then try using just a double splitter and seeing if the moca stays stable for the 2x orbi satellites.
Moca does work as a backhaul. I've both seen it done and tested it myself. So it does work.
So start by simplifying and taking the 6x splitter out and see what happens.
Do you know if its a powered 6x splitter/amplifier or just a splitter? Got a model for it?
What moca adapters are you using?
Hi Plemans,
It’s non powered.
the model is Trix 349806 SCS-6.
MoCa are gocoax MD2500D.
Br Manus- plemansGuru - Experienced User
Those are solid moca adapters. I'd try the removing the splitter for now. If that works, it might be worth checking into an approved 6x powered moca adapter.
- donawaltHero - Experienced User
manusjuhl I agree with plemans that bypassing the six-way splitter is a good test. Could you share, besides its make and model, which ports the three goCoax adapters use?
There’s one other idea I’d check. When the satellite worked with direct Ethernet, I assume it was plugged into a LAN port on the Orbi router? In the current setup, both Orbis connect separately to the TP-Link LAN through MoCA. If the direct test used an Orbi LAN port, it changed the network path as well as bypassing the splitter.
At the remote room, I’d temporarily replace the satellite with a laptop connected to that goCoax adapter. If the laptop gets an IP address from the TP-Link and maintains a reliable connection, the coax path is passing ordinary network traffic, and I’d investigate how the Orbi backhaul works through this arrangement. If it cannot get an address or the connection drops, I’d focus on the coax run, splitter, and MoCA link - the problem is likely there. The goCoax link rates, if available, would also be useful; a lit MoCA LED alone doesn’t tell us how well the connection is working.
Those tests should help separate a coax/splitter problem from an Orbi backhaul topology issue.
I’m lacking an Ethernet port on my PC but I will get an adapter for that tomorrow. I the meantime I have put an old Netgear nighthawk router in the remote room and it delivers internet (Wi-Fi) through that.
i dont know if that is a tell?I have written make and model in one of the other posts.
br Manus
I will try tomorrow - I can put all of them in the same room.
not sure if I understand the last bit. It’s important for me that the Orbi router is not placed where my fiber modem because of the general Wi-Fi coverage.
B Manus- FURRYe38Guru - Experienced User
The moca adapters maybe blocking certain Orbi traffic between the RBR and RBS. May need to try a different kind or brand of MoCa adapters to check this.
As meantioned, check for good ethernet backhaul status with the RBS directly connected behind the RBR, should see WIRED here.
Be sure that the RBS and moca adatpers are connected behind the RBR, then connect the RBS to one of the moca adapters that is connected behind the RBR. The RBS can't be connected in parallel to the RBR. Won't work.
Sorry, you cant interconnect what makes up your WAN and your LAN on the same network - mess is predictable...
To operate WAN (internet feed) and LAN (home network) traffic separately across your coaxial lines, your primary concern is preventing data loopbacks and protecting your network's security/performance.
Because WAN and LAN traffic must remain rigidly isolated to allow your router to do its job, how you approach this configuration depends entirely on your home's physical wiring.
Scenario A: You Have Separate Coaxial Runs (Highly Recommended - not what oyu want, tough...)
If you have access to your central junction box where all room coaxial lines meet, you should opt for physical isolation. This provides the best stability and guarantees maximum performance.
- Isolate the Coax Paths: Inside your utility panel, disconnect the two rooms being used for the WAN link from the rest of the house. Use a standalone 2-way MoCA-compatible splitter (or a simple barrel connector if it's a direct room-to-room run) to connect only those two points.
- Connect the Remaining Rooms: Connect all the remaining rooms designated for your home network to a separate multi-way splitter.
- The Configuration: Keep all four goCoax MA2500D adapters at their factory-default settings. Since the signals cannot physically cross paths, pair one will securely handle your raw internet feed (WAN) and pair two will handle your home internet distribution (LAN).
Scenario B: Everything Must Share a Single Coaxial Network (Frequency Splitting)If all your coaxial jacks must remain wired to the exact same central splitter, you cannot simply rely on the default settings or MoCA privacy passwords. If you do, your router's WAN port and LAN port will accidentally be bridged together over the MoCA mesh, crashing your network.
To resolve this on a shared cable, you must configure the pairs to operate on completely different frequency channels via the goCoax web interface:
- Access the Adapter Settings: Unplug your adapters from the coax network. Connect a computer via Ethernet directly to one adapter, change your computer's static IP address to 192.168.254.10, and navigate to http://192.168.254.254 in your browser.
- Configure Pair 1 (WAN): Log in (Default: admin / pps2020 or check the sticker on older units). Change the operational frequency mode to D-Band Low. Apply changes and restart. Repeat this for the second WAN adapter.
- Configure Pair 2 (LAN): Log in to the remaining two adapters and change their frequency mode to D-Band High. Apply changes and restart.
- Reconnect to Coax: Once reconfigured, you can plug all four back into the shared home coax. The WAN pair will only communicate on the lower frequencies, and the LAN pair will only communicate on the higher frequencies.
Note: When splitting the spectrum this way, the maximum available bandwidth per pair drops from 2.5 Gbps to roughly 1 Gbps for WAN (1 channel) and 1.5–2 Gbps for LAN (3 channels), which is still plenty for most residential setups.Stating that much: I don't have any current MoCa devices - key reason is that modern Cable TV network infastrcures here in old Europe don't have any spare bandwidth - plugging MoCa to a modern Cable TV network would cause another mess - for the other subscribers, and for you.
Hi Schumaku,
I think I have done all of above.
Scenario A: I dont think this is my setup. I only have 1 coax cable to each room and can therefore not isolate them - sorry if i'm misreading
Scenario B: I have done it all and it makes no difference. Just to be clear: The first MoCa (Between fiberbox and TP link - my connection dont work whitout the TP link) is D-Band Low, the MoCa between Coax and Orbi router (Livingroom) also D-Band Low and at last between Coax and Orbi satellite (other room) is D-Band High. Do you agree with this?
There is proberly something simple that I'm missing.
ISP CPE (likely a NAT router, and including WiFi too), plus yet Another TP-Link AC1200 Router (another NAT router and WiFi) - and everything seamlessly connecting each router WAN and LAN again over the single MoKa network....
Looks like some natural grown network infrastructure, with plenty of predictable (and some very obvious) problems.
As someone already suggested, disable any NAT in the ISP CPE (make it a pure Internet bridge). What purpose sgult that TP-Link router have?
Hi Schumaku,
The only reason for me to place the TP-Link router is because I read that it's necessary between the fiberbox and MoCa.
I don't understand your abbreviations (ISP CPE and NAT) Sorry 😞
ISP = Internet Service Provider
CPE = Customer Premise Equipment, rented to say the device you designate as fiberbox
NAT = Network Address Translation - the system that "hides" your private LAN from the public IP address assigned by the ISP - this way your private RFC 1918 LAN IP adresses (I guess your Orbi uses 192.168.1.1 on the LAN port by default.
WAN = Wide Area Network, the network coming to your home on that fiberbox.
Isn't the plan to operate your Netgear Orbi Router as the one and only router to correct direct to this fiberbox? In my option, there should be no other NAT Router (like that TP Link one) in the data path between your LAN with your router (here the main Orbi Router (the Orbi with the port marked Internet (that's technically the WAN port!)
But first, you must physically split your LAN and the Orbi Router Internet port - only establish a direct dedicated physical connection to the Fiberbox.... Otherwise, you will never come away from all te issues you certainly have by interconnecting the WAN and the LAN - because your MoCa is basically physically a d logically connected wrong.
How far is the distance between the Fiberbox and the Orbi Router? The most simple connection would be a simple RJ45 Ethernet cable (max length 100 meters) - and bit connecting your MoCA network to the Fiberbox and the Orbi Router.
Take that other TP-Link router out from the network please.
Just curious, where are you located? Wild guess it might be Denmark 8-)
In Denmark, a fiberbox (commonly referred to locally as a fiberboks, ONT (Optical Network Terminal), or Fiber KAP / KundeAfslutningsPunkt) is the wall-mounted device that converts optical light signals from the fiber infrastructure into electrical signals for your home network.
Reiterating thugs a little bit more: As you apparently have a fiber Internet connection - you still appear to have some Cable TV in your home. Or is that MoCA not connected to your Cable TV provider network? You see, I'm still concerned you might disturb the Cable TV network with that MoCA installation in case you are outside of the US.
Coexisting with Active Cable TV & DOCSIS Internet
If your home actively uses coaxial cable for DVB-C TV and DOCSIS cable broadband from a provider like YouSee or Stofa:
Frequency Plan & Compatibility:
Traditional DVB-C TV & DOCSIS 3.0:
Cable TV and legacy DOCSIS 3.0 operate below 1002 MHz. Standard MoCA 2.5 operates in Band D (1125–1675 MHz). In this configuration, both services can coexist on the same physical line without overlapping.
DOCSIS 3.1 / Extended Bandwidth: Danish operators (like the most common Cable TV providers here in Switzerland!) using high-split DOCSIS 3.1 configurations can extend downstream frequencies up to 1218 MHz. This overlaps directly with MoCA Band D, causing packet loss, modem desync, or complete loss of connectivity.
Hi all,
Thanks for all the great ideas. This will take me some time but I will start from the top and reply you all with my findings.
I will keep you posted.
Thanks once again.
Br Manus
A short update:
I have changed the splitter to a new 2 splitter instead of the 6-splitter.
I have moved the router right to the fiber modem and I disconnected the TP-link - this didn't work, so I connected it again so I have internet through the router. I'm really happy for all your help, but for now it dosen't seem to be the right solutions yet.
Br Manus
Can you clarify what didn't work?
Also, was the Orbi set up as a router (not in AP mode)?
I had no internet in both satellite and router. It was still in AP mode though I had issues in connecting to the Orbi through the backend. I succeded in changing to routermode and now it works. Do you really don't think my (for me) optimal setup can work?
FWIW, one option is to return the Orbi and instead buy two WiFi-7 extenders that can work as access points. Then you could use a 2-way splitter, connecting the TP-Link to room 1 and room 2 using D-Band Extend. The Netgear EXS27 would work for this. This lets you use existing wiring and your three MoCA adapters, and it would deliver your full ISP speed to both rooms.
Which TP-Link model do you actually have? (AC1200 is a wifi speed, not the actual router model)?
It's a TP-Link Archer C64 V1
Also an option.
Last night I tried to move the satellite closer to the router to have some WIFI in the rest of the house. But I cannot still get it to work eventhough the satellite is connected via "WIFI" to the router.
I know i'm not a network specilist but I really have my issues with this.
Br Manus
manusjuhl wrote:
Is it possible for me to then use my current TP link to connect to the 2 rooms with MoCa and also as a WIFI-point.
The C64 is a fast router enough to keep up with a gigabit ISP connection, so it would deliver full ISP bandwidth to the WiFi solution. The C64 WiFi is older (WiFi 5), not the current WiFi 7. If you don't need the C64 WiFi to reach the whole house, then you could just turn the wifi off.
I know i'm not a network specilist but I really have my issues with this.We've already said that you need 4 MoCA adapters to use the Orbi. And that getting your full ISP speed would require getting an additional satellite (as well as another adapter).
The extenders are a path that would let you use the 3 adapters you have, and MoCA wouldn't be a performance bottleneck. The wifi performance for two EXS27 is a bit less than a 2-element Orbi 770, but is still more than enough to handle a gigabit internet connection. So I think it is a better option than 2-element mesh router with MoCA backhaul, and it would be less expensive.
manusjuhl wrote:
Would you think it could cover my entire house 200 m2?
Hard to say if the extenders will cover the whole house. The details here depend on the construction. With wooden construction, the Orbi mesh should give whole house coverage w/o needing a wired backhaul. But that doesn't seem to be working for you.
WiFi coverage is challenging with concrete construction - not just because of the mass, but also because iron rebar in the concrete. Another difficult challenge is when the walls have metal studs instead of wood. Some homes also have interior metal lath for plaster, which will block WiFi. I am guessing that you have one (or maybe more) of these challenges.
What we do know is that the extenders (running as Access Points) would give you great wifi in the two rooms with existing wiring and no additional MoCA adapters. If they don't cover the entire house, you'd need to add another extender (and get another MoCA adapter.
Transitions from one room to another might not be as seamless as with the Orbi. You might sometimes need to turn the phone or laptop wifi on/off connect to the best extender for that location.
Is it possible for me to then use my current TP link to connect to the 2 rooms with MoCa and also as a WIFI-point. And then also to do what you suggest with 2 boosters insted of the Orbi?
Would you think it could cover my entire house 200 m2? (Otherwise it could "just" buy one more and connect though WIFI?)
Its my last day of returning the Orbi, so hope you can help me fast :-)
So just asking, the following configuration doens't work with the MoCa adapters?
ISP modem>Orbi RBR<><ETH/Moca adapter connected behind RBR>ETH/Remote MoCa adapter<>Orbi RBS?
