acmorton's avatar
acmorton
Orbi and Private Relay on iOS and MacOS
We are in the process of trying to upgrade from an older Orbi RBR50v2 setup to a new RBE371 wifi 7 system. The main reason is that Private Relay from iCloud+ stopped recently working and we have to turn it off for our devices and apps to make it out onto the internet. I thought by upgrading to the newest system and standards it would solve the issue, but we're still having the same issue and have to disable Private Replay on both iPhones and Macs to be able to receive data. This is a new and recent issue. We've tested at other houses with the same ISP but different equipment and Private Relay works fine. Is Orbi no longer compatible with Private Relay?
  • CrimpOn's avatar
    CrimpOn
    Apple's Private Relay should be transparent to a home WiFi router (of any brand).
  • FURRYe38's avatar
    Only items we suggest during off while at home is Private WiFi Address. https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046
    I been using Private Relay on my Orbi AX and BE systems with out issue.
    What model phones do you have and what iOS is loaded on them?
    • acmorton's avatar
      acmorton
      Hi, we're using iPhone 15 pros, all running iOS 26.0.1. We updated the BE system to the latest firmware 12.1.3.11. We don't have a modem on the house, just direct fiber from the ISP into the house and to the router. I'll check the article above. If anyone else has had this experience I'd like to hear how and if you resolved it. Thank you!
