afight's avatar
afight
Guide
Apr 22, 2025
ORBI dropping connection - replaced same issue - with VPN works
After 5+ years of no issues, I started having devices dropping and not able to load on my Orbi RBR50. I made the $1300 upgrade to the RBE971 and am having the same, if not more problems.
Here are some things I notice -
1. for whatever reason it seems like most tvs are streaming fine.
2. Loading websites is an issue even when on a wired connection, but other items that require connectivity work fine. If I connect to my VPN, websites work again.
3. I had my ISP out and all checked out. They set up their router and everything worked perfectly for a few days. When I went back to ORBI, nothing loads.
WiFi is basically unusable on phones and computers. The only thing that I can think of that changed is that we got new neighbors. We have 1 acre lots so they are not close by and I have checked to see that we are on a different channel.
I have had a ticket open for over a month with netgear and have had little to no response on troubleshooting. Help!
