procreator's avatar
Jul 24, 2026
Orbi RBE360 and Epson ET-3958
After spending way too much time with Epson tech support, I was told that even though their printer was compatible with 5gHz or 2.4gHz, it does not play nice with mesh router systems. Their suggestion was to use a LAN cable to connect the printer directly to the main unit of the Orbi.
In my situation, it is not really workable as I cannot locate the printer where I can also run a cable.
Any other ideas?
Thanks!
  • Thanks for all the ideas.
    I bought a cheap TP-Link WiFi Extender with an Ethernet port. The extender plugged into a wall outlet 4ft from the printer.
    Works great!
  • plemans's avatar
    Thats got an older wifi 5 chip in it. Some had issues with AX much less BE. I can't remember if that version of orbi has an IoT option. If it does, set that up with wpa2 only mode. see what happens. You should have wpa2/wpa3 mixed mode running for wifi security.
  • FURRYe38's avatar
    Seems like if the printer has a Ethernet port, connect it up to the RBR or RBS directly and point your printer drivers to it's given IP address here.
    Ethernet cables come in many lengths.
    Works great!
