golf18
Oct 27, 2025Tutor
RBE770 and Sky Hub
Hi,
I have just upgraded my RB50 due to end of life to a new RBE770 and RBE771. All set up but last night my sky Q box could not log on to the sky Hub. I am wondering if the new setup is blocking the Sky wifi.
I reinstalled my old system and it works at the moment, just reinstalled my 770 and seems to be working.
I have moved the position of the 771 router away from the sky hub my question is should I set the 770 to AP mode?
Something to contact SkyQ ISP about regarding there equipment.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communitieshttps://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Couple of options,
Try option #2 first... - KevinLiTNETGEAR Moderator
Hello golf18 ,
Welcome to the NETGEAR Community!
I understand that you would like more information about configuring the RBE771 to work with your existing network infrastructure.
FURRYe38 Was correct in this matter.
Since there has been no network configuration changes, the issue was most likely caused by your internet service provider.
The question about using the Orbi Mesh system in AP mode depends on your networking needs. If you are using your Orbi system to simply extend your wireless network, then you would benefit from placing your Orbi Mesh system in AP mode.
However, if you a complex network setup that includes devices such as privately hosted DNS servers, then it will be beneficial to enable bridge or pass-through as mentioned by FURRYe38 on your ISP router.
Best,
Kevin
NETGEAR Team
- golf18Tutor
Thanks for the replies now ok
Let us know how you got it working.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
- golf18Tutor
Thanks all for your advice have set Orbi to AP mode
