krgoodwin's avatar
Jan 15, 2026
RBE970 Satellite Connections
Why does a WiFi device 10 feet away from the satellite end up connected to the Router RBE971 which is a 100 feet away? I've also seen where devices close to the satellite initially connect to the satellite but the next day are connected to the Router.
Anybody know the WiFi thruput rates with respect to distance.  I remember some on the newer WiFi  protocols actually got slower as their distance from the access point decreased; in other words, being too close had a negative impact on thruput.
  • FURRYe38's avatar
    Something to check with the devices Mfr. Up to them to pick and choose where they connect and migrate to and from.
    Speed will decrease with distances, noise and interferences.
    • krgoodwin's avatar
      krgoodwin
      Guide
      Not an accurate statement.  For some of the newer WiFi frequencies and protocols, the speed will decrease as the distance decreases.  This is usually considered the near field environment.
      • FURRYe38's avatar
        Yes and also depends on how the device picks and chooses which frequency to connect too. Some detection algorythms may not be good with client side devices. I found this out with NEST controllers back on 2020 with Orbi AX series. Would ping pong around unable to connect to multi signal AP configuration. Worked with NG for months on this and was determined NEST had to make some changes there side to help the controller work with multi singal source systems and stop the ping ponging around.
        Placement of the RBR and RBS and how many RBS are deployed and distanced in between are also a factor for Orbi systems.
        Orbi systems are multi signal sourced systems while the R9000 is only a signal source signal router.
  • CrimpOn's avatar
    CrimpOn
    When a mesh system boots up, such as after a power outage, the router is the first device to begin broadcasting WiFi.  While many WiFi devices scan constantly to seek a better connection, there are some devices where the WiFi software connects to the first signal that it recognizes and quit looking.  What happens if this device is powered off and back on again?
      krgoodwin
      Guide
      I have had for years the same question because I've seen this same 'odd' outcome in both the newer Orbi WiFi 7 (Orbi 971) and the older Nighthawk (R9000) systems. Why does a device connect to the router when the satellite is CONSIDERABLY closer?  As mentioned by CrimpOn, I can force the device to attach to the Satellite by manipulation of the power-on sequences resulting in the common sense attachment of the device to the nearby satellite but the next day, the device in question has decided to change and attach to the Router which is considerably further away (3 feet distance to the satellite versus 100 feet distance to the router).  I can guess that possibly the attachment to the distant router is still a viable signal and thus going thru the satellite is not necessary but it violates my understanding of mother nature that for over the same exact path, the WiFi signal distance is inversely proportional to performance, i.e., speed.  Over the years I have also come to the conclusion that the Attached Device display is not to be trusted being that most likely within a mesh network device attachments are very dynamic.   And for the 'experts' who will want to question my conclusion regarding signal strength versus distance for all the WiFi frequencies which I know to very complicated especially in terms of short versus long distances, I've tried placing the device in question at various distances (far field/near field) from the satellite (or extension as the Nighthawk system called them) and still see the same outcome - the device will attach to the further away router than the closer satellite/extension (specifically separation test case distances of 3/100 and 35/65 where obviously the 35/65 case can not be considered the same path).  Experimentally I've seen where the slightest difference in the physical signal path can result in significant differences in signal strength at the router.  When you can do signal path tracing and see exactly how obstructions impact the WiFi signals, it all begins to make sense - it is just not intuitively obvious.  The primary lesson you learn is that the WiFi environment is extremely messy and secondly, without computers, WiFi would never exist.
  • CrimpOn's avatar
    CrimpOn
    Is this repeatable?  If the device is powered on when both the 971 router and the 970 satellite are already active, it chooses the nearby satellite (which is the expected behavior).  Does this happen reliably? (every time)  i.e. power it off.  Power it back on and see what it connects to.  (several times).
    If left connected to the satellite, is there a pattern to the device switching to the router? (every night?  some nights?  sometimes during the day?)
    One possible explanation for the device changing from satellite to router could be that the satellite WiFi signal disappears for a short time.  Although the device may not be programmed to "keep looking for a better signal", it almost certainly will begin looking if the WiFi access point it is using disappears.  "Oh, there's one I know the password to" (the router) Once connected, it falls back to staying connected and not looking for a stronger signal.
    I have a sense that there have been discussions on the forum about 970 satellites dropping connections, but not having one I have not followed them closely.
    Not certain what tools can be used to document when specific WiFi signals are being broadcast and when they are not.
    p.s. What device is this?  If it is under $30, I'll have Amazon bring me one to experiment with.
