breaksfr123's avatar
Apr 01, 2024
RBE971 Firmware Version 9.12.2.1 Issues
Hi I upgraded my Orbi system (1 router + 2 x satellite) approximately one month ago, and upon installation through the Orbi app, it automatically updated the firmware on all 3 devices to V9.12.2.1_1.2.10.
I did as per usual and personalised the settings to broadcast the existing SSID of my router and when doing so noticed a new network with SSID "NTGRBH_[MAC address]", which I found unusual. I then checked the MAC address of my router and also verified via the native WIFI scanner on my iPhone and see that the MAC addresses differ by one letter.
This leads me to believe it must be broadcasting some sort of backhaul channel (you'll forgive any misuse of jargon please!).
Whilst this is most likely not problematic, it doesn't seem ideal to be broadcasting MAC addresses like this. I phoned netgear who, after speaking with not less than three agents over three days, scheduled a call back which I received this afternoon.
Netgear says that this is a known issue that will be corrected by way of a firmware update...with no ETA.
Is this something I should be worried about?
Ah, and my satellites wont reconnect if I reboot my router. I have to factory reset them each time, otherwise they both go magenta despite having a great connection when they do successfully connect.
Could these two issues be related?
For info, my ISP set up is with Community Fibre and gave 3gb up/download and have the orbi router connected to an Adtran ONT.
Thanks!
  • FURRYe38's avatar
    What region are you located? Just be sure that this version of FW is for EU region users only.
    Yes, the NTGRBH_[MAC address] is a know thing and is not accessible by anyone, only the RBS and the RBR use this. Yes been like this since the start and NG is aware of it and hope they will eventually hide it for good.
    RBS should reboot along with the RBR and reconnect give 5-10 minutes to come to ready and fully sync and optimize.
    I presume up updated the RBS first, along with the RBR lastly?
    • breaksfr123's avatar
      breaksfr123
      Guide
      Hello,
      I am located in the UK.
      I did not need to manually update the firmware. When I activated the system through the Orbi app, it installed the new firmware.
      I'm still running into a problem whereby if I reboot the Orbi router, I have to reset all three satellites and add them back for them to connect, but this seems like it is unrelated to the firmware issue.
  • FURRYe38's avatar
    Any progress on this?
    Thanks!
      breaksfr123
      Guide
      Hello,
      I have reset the system with Orbi tech support more times than I can remember. Level 2 support said that this is a known issue (i.e. the broadcasting) and would hopefully be addressed in a future firmware release.
      I am still working with them regarding the satellites not connecting after rebooting the Orbi router and have sent 3-4 sets of debug files. They just keep coming back asking me to do a slightly different procedure than the previous time.
      I'm a bit fed up by this point to be quite honest. The system is expensive, and I do not think it is fair to expect this level of involvement from a consumer to find the issue, which must either be the firmware or the device.
      I would not have thought that broadcasting the MAC address would be a function of the channel configuration (auto for 2.5 ghz and 48 for 5 ghz), the distance between satellites (30+ feet between each) or how many satellites I have deployed (3 satellites in all). Why would this cause the mesh to expose a backhaul channel (not sure this is the right term)?
      Thank you
      • FURRYe38's avatar
        I would ask them about a RMA at this point.
        Yes the backhaul broadcast is a known thing. It's been there since the beginning. It does not cause problems from the RBS or to the RBS. You can ignore that for now.
        However if the RBS are having issues getting connected to the RBR and keeping connected, I'd ask for an RMA. Yes this system is too expensive to be hassling with all this troubleshooting. I'd ask about an RMA for sure. Do you have a case number by chance?
