kjx
Aug 04, 2024Apprentice
Re: Orbi 970 Constants Reboots - Solved!!! (Router overheating is the cause)
I'm the OP in this thread and I'm unable to reply to it with an update so starting a new discussion as the outcome is important to share --
"Orbi 970 Constants Reboots - Solved!!! (Router overheating is the cause)"
So, I finally received my RMA units (looked like a brand-new box with router and satellites, everything sealed). Replaced everything and sent all of the original equipment including satellites back. Netgear Armor started over with a 1-year sub.
Great news overall - sharing the exact update I left in the support case --
(A) Overheating & connection drops. (good)
I can confirm that the new equipment does not overheat – I stress-tested it with a 52 GB game download (peaking at 250 Mbps down). This was one reproducible scenario that caused the previous router would have issues with.
Even though everything is fine, for hardware longevity, I still plan to run fans over the router.
(B) WiFi-6E issues (resolved through satellite movement) --
The second problem where my WiFi-6E devices in a particular room would randomly lose connectivity (that engineering thought the logs looked weird on).
- This still happens on the new equipment. Same weird IP address assignment, etc.
- But I resolved this myself in the end by moving a satellite and placing it directly inside the room with direct line-of-sight to all 6E devices (going from a wired backhaul to a wireless backhaul).
- My devices near the satellite have higher pings (marginal at 10 ms) and marginally lower speeds (1.4 Gbps down to 1.2 Gbps up/down to my iPad) BUT the connection seems perfectly stable to multiple WiFi-6E devices in that room.
- kjxApprentice
Clarification to the post above - the peak download speed in the stress-test was 250 Megabytes per second (MBps), which would translate to 2+ Gigabits per second (2 Gbps).
Glad the RMA solved it.
Ya, I run a fan on mine all the time, regardless. Helps keep it cooler and helps with HW longevity in the long run.Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡Just an update on my similar situation. After trying all the detail from Furry, adding fans etc, still had restarts. Netgear started an RMA and I've set up the new setup and am monitoring. No issues so far but it's only 3 days. Hopefully it was the original router causing all the issues and overheating. Appreciate all the info in this forum.
