conroyw's avatar
conroyw
Apprentice
Dec 05, 2025
Satellites aren't picking up any devices
I just purchased another RBE770 to connect to my existing mesh network to work a perceived coverage issue.  I have a 3 story home with approximately 2400 square feet per floor.  The new device is incapable of finding any satellites in the network.  I drilled into the 2 satellites and see they are carrying none of the devices in the house.  I attempted to open a ticket with the new satellite to see if I could get it to event connect to the mesh and it can't find any devices.  The new satellite is 15 feet from one of the other satellites.  I can see the 2 theoretically working satellites in the orbit app.
I attempted to open a support ticket with the bot.  It took the serial number of the device and when I tried to select it from the bot all my devices are now missing.  Is there any way to actually get to a human before I replace this equipment.  Are there any suggestions for what to check to see why all the devices in my house are only capable of connecting to a router in my basement instead any of the 3 satellites distributed throughout the house?
I am absolutely unimpressed with their equipments performance and inability to get any support.  I have been using netgear equipment for many years and it seems they no longer are capable of supporting their products.
  • I left it a while and now all devices are reporting good.  I does seem strange the devices went out of synch, they are all set to auto update.  I didn't trigger the update which put router on different firmware version than satellites.
    • FURRYe38's avatar
      And now are the RBS at same FW version as the RBR?
  • the satellite that is wired also shows a status of Config Synch.  Any idea what that means?
  • I was able to connect my satellite to the router.  The satellites to are all on 10.5.19.5 and router is V10.5.20.7_2.2.48.  I have one of the satellites connected via ethernet.  Looking at the admin console I can see 3 of the satellites are showing connection type as 5 GHz + 6GHz and the wired one only shows 5 GHz is this normal?
    • FURRYe38's avatar
      How was the system updated? Manually? RBS should be updated first to v.20 FW version, then update the RBR lastly.
      Config Sync means that the RBS and RBR are still finalizing the sync. Takes a few more minutes maybe. If RBS are ethernet connected Config sync should change to WIRED. If RBS are wireless, should 5GHz + 6GHz meaning MLO is active between the RBR and RBS.
  • FURRYe38's avatar
    What does the RBRs web page show in a web browser?
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    15 feet is TOO close in between the RBS. 30 feet or more.
    What mobile device are you using? Android or Apple?
    What version of the Orbi app are you using?
    No bots in the system here. Find support in the forums or here: https://www.netgear.com/support/
  • And to add insult to injury I logged back into the orbit app after interacting with robot and all satellite devices are gone from my network map.
