notCB's avatar
notCB
Two devices can't ssh or ping
I have two devices, a Mac and a raspberry pi, that are connected to the same orbi satellite on the same main wifi ssid and same subnet using DHCP. The Mac is connected at 6Ghz and the pi is connected at 5Ghz. After several hours both can ping the Orbi router but they cannot ping or ssh to each other.
If I switch the Mac to the IoT SSID and then back to the main SSID both can ping and ssh to each other. Sometime just restarting the Mac's wifi connection works. Wait a few hours and the same thing happens again. This behavior is seen on other devices on the network. I've changed the wireless channel from auto to a specific channel but that doesn't seem to help.
Both Orbi devices are up to date. Is there anything I can do to maintain a stable connection?
  • I have RBE971 and RBE970 with firmware V12.1.10.12_5.3.16. Have not tried disconnecting the satellite to connect to the router. Currently testing with the Mac hardwired to the satellite. The mac is using private wifi addressing (MAC address randomization). I can turn that off as the next test. Also, while the problem was occurring, I tried flushing arp cache on both devices and also rebooting both. That did not help.
    My Sony TV and a few other devices randomly loses their wireless network connection. Not sure if that is related. Have not had the time to study it.
    By the way, I have a fair amount of experience in networking and software development. As far as i can tell right now, this setup should work and it does work for a few hours.
    Thanks.
  • I'm using channel 6 for 2.4 and channel 40 for 5. Changed to 1 and 40. The distance apart is about 50 ft and 2500 sqft. The local orbi web page is not showing any new patches.
    Model NameDevice NameCurrent Firmware VersionStatus
    RouterRBE971RBE971V12.1.10.12No New Firmware Available
    SatelliteRBE970Orbi Satellite-1V12.1.10.12No New Firmware Available
    • FURRYe38's avatar
      Your system may not be in the auto update service list. So it won't see it. NG pushes updates out in small batches so will be more time or manually update as meantioned. I prefer to manually update systems my self.
  • An update. The problem seems to have disappeared after hardwiring the Mac to the satellite. This is not ideal since some of the Mac's features rely on wifi. Next, I will test wifi with the Mac's MAC address randomization disabled.
    • FURRYe38's avatar
      Still using same FW version you posted?
