krgoodwin
Jul 14, 2026Apprentice
WAND Disconnects (Hunter Irrigation)
I've had a Hunter WAND WiFi module in my X2 controller (irrigation system) since 2024 and it seems that after the latest RBE972S (Orbi 970/Orbi 971) firmware updates to Version 12.1.10.12, the WAND WiFi module randomly disconnects. The NETGEAR firmware update solved a number of prior problems (Google Pixel 10 smartphone) but the WAND WiFi module disconnects seem to have started after the latest firmware update. I've spent a fair number of hours attempting to resolve this problem going thru all of Hunter's recommendations and went so far as to purchase a new WAND module. No joy, the WiFi module seems to be losing the Internet connection but none of my other 30 connected devices are experiencing a similar problem. I have a full strength 100% WiFi signal at the module since the Orbi 970 Satellite is 50 feet from the irrigation system controller. I do notice in the Bluetooth interface, that after the disconnect and a subsequent reconnect in XXX seconds, the Internet connection is Poor (14%) with the Hunter Hydrawise controller is marked Failed. Anybody experiencing a similar issue with the WAND module for Hunter X2 Controllers?
- krgoodwinApprentice
In my latest experiments, I noticed that the Hunter Irrigation WiFi software was recently updated (never any notice). So far the reinstalled WiFi module is holding so I am hoping that the new software has corrected the disconnect issue. Thanks for everybody's suggestions - appreciated.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
After wasting my life on these types of problems, it turns out that the disconnect issue is a legacy hardware issue. I was having the same disconnect issues with my Generac generator except this problem would not even let me reconnect the WiFi module to my network - even after working for 2 years. Between me and a knowledgeable support person, it turns out that the WiFi module only connects if constrained to a 2.4 GHz specifically named SSID. For the Orbi 970/971 mesh network equipment, an easy way to accomplish this was to instantiate an IoT network which allows specifying 2.4 GHz only with its own SSID. So far everything is once again working. I also went ahead and put some of semi-IoT equipment, e.g., refrigerator, on the now new IoT network. With a new understanding of what an IoT network is all about, it makes a lot of sense. I don't want to impact my watching of Dr. Phil everyday (lol). When I go back and look at the first thread response, sure enough the alternate network (guest, IoT, etc.) was suggested.
- DavidWilson0Aspirant
I'm seeing something very similar with one IoT device after the latest firmware update. Everything else on the network stays connected, but a single device randomly loses its connection after hours or even days. It will be interesting to see whether this turns out to be a firmware issue or something specific to certain IoT devices.
- KevinLiTNETGEAR Moderator
AtHello krgoodwin ,
Welcome to the NETGEAR Community!
I understand that you have been experiencing issues with your RBE970 wireless connections with your IoT devices on firmware version 12.1.10.12. I have taken the liberty to endorse you to our experts due to the premise of this issue. At this time there is no action required on your behalf. Please monitor your email for contact attempts from our experts.
Best,
Kevin
NETGEAR Team - FURRYe38Guru - Experienced User
Does this happen if you connect this one devices to the Main WLAN, IOT or Guest network?
This the only device this is happening with?
Does this happen with the device if you bring it near the RBR just to test and see if it keeps connected?
Can you get this controller a bit close to the remote RBS to check and see if it still happens or not?
The disconnects are with my only network which I presume is the main WLAN. I am planning on connecting it to the Guest network (once I turn it ON) to see if that changes anything. This is the only device I am having disconnect issues with since the latest firmware update took care of the Google Pixel 10 Internet drops. Can't easily bring the irrigation system controller any closer to the satellite or the router. The satellite is on the other side of the garage (50 feet with a clear shot) and the router is probably 75 feet away inside the house (two walls intervening). The WiFi signal strength is reported in the Hunter Hydrawise app diagnostic as High with a 100% Internet connection when connected to my network which can be for a number of days. Why does it decide n number of days later to disconnect? Especially when it ran for two years with no problems.
Let me clarify some of the above. I am planning on connecting the WiFi module of the irrigation system controller to the Guest network. The signal strength has to be "5 bars" as they say since the Wifi module is only a three car garage distance away from the satellite. The satellite (RBS) is probably 175 feet away from the router (RBR) with the WiFi module separation distances mentioned in the previous posting but the WiFi module is slightly closer to the satellite than it is to the router. Once I've got the WiFi module connected to the network, it can be up to two days before I experience a WiFi disconnect. Sometimes it is only a few hours thus what I perceive as random disconnects. BTW, thanks for the interest - appreciated.
