jim_l's avatar
jim_l
Tutor
Sep 20, 2019
1.0.1.64_1.0.27 firmware update
Hi,
My RAX80 is showing 1.0.1.64_1.0.27 firmware as being available for update (from 1.0.1.62) but I can't find any release notes or futher info anywhere. Does anyone have any more info?
Thanks.
  • New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: 1.0.1.62_2.1.46.1 New GUI Language Version: 1.0.1.64_2.1.46.1 Current Firmware Version 1.0.1.62 New Firmware Version 1.0.1.64_1.0.27 Release Notes:  1.   [Security Fixes] This firmware fixes security issues.  2.   [Bug Fixes] The correct 5 GHz channels now displays when the Korea and India regions are selected.  3.   [Bug Fixes] The default Beacon interval is now set to 100 and the DTIM is now set to 3.  4.   [Bug Fixes] Channels 1, 11, 12, and 13 will no longer be used when the 2.4 GHz channel is set to Auto.  5.   [Bug Fixes] Client devices with only IPv6 address are now able to access the router web interface using www.routerlogin.com.  6.   [Bug Fixes] Fixes minor bugs.
    • jim_l's avatar
      jim_l
      Tutor
      Strange. The Release Notes section is blank for me.
  • Has anyone actually managed to upgrade?
    I kept getting the GUI Language file cannot be upgraded.
    • SAM_the_GAM's avatar
      SAM_the_GAM
      Luminary
      I was able to upgrade successfully. The LAN / WAN devices still disconnect at random but I was told by another user to turn MU-MIMO off and that resolves the issue. Testing it out now
        SAM_the_GAM
        Luminary
        Even with MU-MIMO disabled the WAN / LAN still randomly disconnect / reconnect throughout the day with this latest firmware. This bug was first introduced in the 1.0.1.58 firmware. Back to 1.0.1.56 I go.
  • this is a broken firmware. I have done a reset after update to get a clean install. But this firmware has hard connection drops in wireless lan, the GUI can be reached sporadically only and I can not set settings for NTP. How can netgear just bring such a laggy firmware for this expensive router?
    I rolled back to 1.0.1.40
    • xjn's avatar
      xjn
      Apprentice
      I was able to update and mine is working okay... but still have issue with random LAN disconnects and QoS randomly enabling causing speed to be capped at exactly 500Mbps... also have issue others reported with Device names not saving and other various issues. For most part it works but frustrating so much of basic functionality is broken for the price.
    • bevant's avatar
      bevant
      Apprentice
      I find that my port forwarding entries disappears after a reboot. Traffic Meter also gets disabled after a reboot. TImezone and NTP gets reset.
      For NTP, I change it to time.google.com instead of using the netgear default. It works.
      I was wondering why I would lose internet access and blamed it on the ISP but now I know it's the router!
      Literally, this is the worst Netgear product I've ever purchased.
      • xjn's avatar
        xjn
        Apprentice
        I have only had one other Netgear router... ten years ago and it was so bad I gave it away lol... not sure why I decided to try Netgear again but here I am... I guess it works decent if you are type of person that just uses default settings. If want to change anything though it's very hit or miss.
    • bevant's avatar
      bevant
      Apprentice
      Is this the last stable version? I'm getting sick of having to restart the RAX80 almost every day when the network suddenly drops dead. I want to roll back to the last version which doesn't drop the internet connection just because "it" is having a bad day.
      • Spoone123's avatar
        Spoone123
        Initiate
        1.0.1.40 is the most stable to me as of now, I had to restart my router once this month. I do sometime get some weird bug where i have to click go twice for the website to load. I about to return this router to my local Best Buy and get the ASUS one instea , they have Ai Security feature and 8 1 gig port for LAN.
  • I managed to update my router this weekend.
    As a side note, the update is only available through the router WebInterface. The Nighthawk app says my device is up to date.
    Flashing was quick & fine but after restart all of my issues with wifi constantly dropping, devices unable to connect came back.
    I had to performed a factory reset, manually reconfigure the SSID, AccessPointMode, SmartConnect & disable AX functionality to get back to normal performance.
    The update doesnt seem to address any of these big issues with the router so I would recommend everyone to avoid installing it until theres some better feedback from Netgear.
