Pzrldralt
Dec 06, 2024Aspirant
AX12 speed drops
M1000v2
I had a Nighthawk 7800 router that began experiencing internet speed drops. A friend who is an IT tech suggested I buy a new router since it was about 5 years old. I bought a Nighthawk AX12. I have a Netgear CM1000v2 modem and the whole is hard wired to the PC, NO wifi connection. The new router is 2 days old and today experienced another random disconnect and speed drop. I called the ISP ans spent around 30 minutes with them doing tests and checks. The ISP had me do a direct connect bypassing the router which fixed the issue.Going back to the router it again experienced random speed fluctuations. I pay for 600mg service and all line tests showed no issues and ISP logs going back several months were also clean. The speed drops off to just 90mg through the router. When first started up the router auto downloaded and installed the new firmware as I expected.Asking the ISP tech as well as my friend about any speed settings for the router they both told me there were none they knew off. It's not the ISP or modem. I also replaced both cables with new.
So, the question is WHY is this happening even to a brand new router?
So you have the RAX120?
What FW version is loaded on it?
e sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Are you using the Yellow WAN port or the Multi Gig port for the connection to the ISP modem or ONT?
What device are you using to speed test with?
Armor, Smart Parental Controls or Circle, Protection Engine, Traffic Meter.- PzrldraltAspirant
The router auto updated the firmware upon internet connection.
Both cables are new, yellow for the modem/router connection and a new Cat5e for router PC connection.
Internet port is clearly marked, the Multi port is used for the PC connection.
Testing is done by my ISP, my IT friend and myself on Speedtest.net. The hard wired PC is used for testing. Access speed is normally 660mg/23mg
While working with the ISP on this issue they had me run the modem straight to the PC and the speed test was normal. They checked the modem and found it working normally.
Prior I had 90/15. After the router was put back in the system the speed dropped back to 90/15. A few hours later I ran another speed test and it was normal. This morning I checked again and it was normal. The speed drops are totally random.
Router settings are factory default besides setting up the Wi-Fi for other devices.
What is your new router?
AX12 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
RAX120? RAX200?
Did you run the new router through its Internet setup wizard? You may need to reset the CM1000v2 to get it to forget any relationship with the R7800.
On which, "buy a new router" seems to be a bit heavy handed. Did you try anything to fix that issue? The R7800 (2016) may be a bit aged, but the RAX routers (~2018) are hardly that much nearer to the bleeding edge.
Just another user with time on their hands.
- PzrldraltAspirant
Model is RAX120'
Just experienced another speed drop.This time the router was flashing orange on the Multi Gig port which is where the PC was connected. Switched to port 1 and speed returned to normal.
The old Genie software isn't compatible with the new one and yes, it ran through the Setup Wizard on startup. The router has been cycled more times in 3 days than the old 7800 was in it's lifespan.
The 7800 was replaced at the suggestion of a friend of mine who is an IT tech. He pretty much ruled any other possible issue. He's been a tech all his life, some 45 yrs experience.
Perhaps you have discovered the solution.
Not sure what you mean by "old Genie software". If you mean the mobile app, then you can use the Nighthawk app instead. But in general it is preferable to use a web browser and the graphical user interface. That gives you more control over things that are beyond the apps.
Netgear is trying to kill the desktop genie, but for the time being you can find it here:
genie | Product | Support | NETGEAR
Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress.
He pretty much ruled any other possible issue. He's been a tech all his life, some 45 yrs experience.We've seen those claims here often. But they don't add up to much without a bit more than "trust me I am an expert". Replace a troublesome router with another router that causes issues, and you have to suspect that some other factor may be involved.
We don't know what was going wrong with the R7800. Any number of things can lie behind "internet speed drops".
I am sure you asked this veteran for help with the new router. What did they say?
My first "modem" was an acoustic coupler, followed by a dial-up modem. But I wouldn't claim that that gave me any great insights into modern routers.
