briandconnolly
Jul 05, 2021Aspirant
AX120 Dropping Connection
Ever since upgrading to Firmware Version V1.2.1.22, I get sporadic dropouts where I am asked to resubmit my password.
Thoughts?
SETUP
Fedora 34 w/ Gnome 40
Smart Connect enabled
Access Control Turned On
Thanks.
Brian
- microchip8Master
Try without Smart Connect. On NG routers, SC isn't working as it should in a lot of cases and NG seems to break it every now and then.
- briandconnollyAspirant
Roger that. As a test, I turned off Access Control and rebooted. And as the issue is sporadic, I need to let it sit for a while.
I'll try your solution next, if need be, and report back.
Thanks for the prompt reply!
You were right. Diabling AC did not fix it. Disabling Smart Connect seems to have done the trick.
Thank you!
