aalexandrebeta
Mar 03, 2019Master
AX6000 RAX 80 print server absent!!!!!
Why is there no print server feature on that router?
It is like if a ferrari was not provided with reverse gear!!
What is wrong with that picture????
DarrenM
Mar 05, 2019Sr. NETGEAR Moderator
Thank you for pointing out the error in the datasheet this will be corrected. As for Readyshare print, this is not a feature currently on the RAX80 but is something you can request over on the Idea exchange board that I posted below.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Thanks
DarrenM
aalexandrebeta
Mar 06, 2019Master
DarrenM you should be ashamed to present things like that. Netgear did not do any work at all into fulfilling their duty to provide some decent features on that product.
Your hardware is OK but the FW is a nightmare. Your FW remind me of Windows 10 a bloatware OS!!!!! 40GB of size for only the OS while on the process Linux is taking only 5!!!!!!!!
So shake the coconut tree a lot wake the nerds designing the FW and feed them when they did their work!!!!
I am thinking into migrating my device on Open-WRT because free products are better then paying products!!!!
If food stores acted like for example Netgear they would have close a long time ago!!!!!!!
RESPECT THE HAND IS FEEDING YOU PERIOD!!!!!
