jeadams's avatar
jeadams
BUG REPORT Nighthawk® AX12 RAX120 Router Firmware Version V1.0.0.84
Choosing option  WPA2-Personal[AES] + WPA3-Personal  encryption  disconnects IPAD 2 running IOS 10.3.3
Must choose WPA2-Personal [AES] to stay connected.
    • schumaku's avatar
      schumaku
      Christian_R  - that's a bug, not a security vulnerability. Perfectly chosen subject by the OP 8-)
      • kc6108's avatar
        kc6108
        Luminary
        jeadams
        Did you ever get this issue resolved? I'm interested in purchasing the RAX120 but not if simple test cases like this are present.
        Also, the response you got from the moderator Christian_R was totally unacceptable and way off base. You should contact support if you are still encountering this issue. Make sure to reference this forum thread.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jeadams
    Are you able to upgrade your Ipad to atleast 12.1.1 or greater IOS version? The older version of IOS does not support WPA2-Personal[AES] + WPA3-Personal  encryption.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Hello jeadams
    DarrenM
    • schumaku's avatar
      schumaku
      These old iPad 2 don't get any more updates. As a WPA2 device it has to associate the new RAX and run reliably.
      • mbze430's avatar
        mbze430
        Guide
        Surface Pro 3 with the Marvell Wifi will not connect when set to WPA2+WPA3.  Will connected fine WPA2 even with AX enabled.
  • I'm running V1.0.1.108 and performance is horrible in AP mode. Spent several hours over the last day trying to debug slow speeds. Finally did a system reset and used the app (not via routerlogin.net) to initialize. Then all my devices were hitting 6-700Mbps... iphone 11 pro max at 800Mbit+. Left it overnight to be sure it would stay there and it did so I just changed to AP mode, nothing else and speeds dropped to around 200Mbit range. Flipped it back and it stayed slow and had to do another reset to gain back the speeds.
    I'm a highly technical person and would be willing to work with engineers on the root cause. Perhaps when I feel like it, I'll do some debugging in telnet
