MAD5
Nov 28, 2022Tutor
Can't see 6 ghz on RAXE500
I try with my S22 Ultra and only connect to WIFI 6 but not 6E. It doesn't appear on the list. Only 2,4 and 5 ghz. Also try with my notebook Lenovo which has Intel AX210 with windows 11 and lastest Intel drivers. It shows the 2.4 and 5 ghz but not 6 ghz. I also updated the firmware to V1.0.11.94_2.0.44
Are you using smart connect?
Have you tried disabling it?Have you tried changing what channel the 6ghz is on?
- MAD5Tutor
I don't use smart connect because it only works for 2,4 and 5 ghz. I also tried changing the channel with and without PSC, still the same.
You're a little stuck. Reason I say that is there aren't scanners (free ones) that support 6ghz so you can do a scan and see if its truly not working, or the if the devices aren't picking it up for some reason.
Did you try factory resetting the raxe500?
If so and it doesn't help, you can try contacting support.
What Intel Driver version are you using?
- MAD5Tutor
22.180.0.4
Like this is a new router I update to the last firmware before even touching anything else. Anyway it has been reset 3 times since FW update and no luck.
And is the 6Ghz LED On on top of the router?
Does the 6Ghz section appear on the Advanced Tab page on the routers web page?
Post a screen capture of this?
I have mine running in Bridge mode and had been working on 6Ghz with my Orbi 9 series. Now its back on 5Ghz with my 8 series Orbi system. I'll check this on mine when I get home today....
