BrentW1975's avatar
Dec 28, 2019
Devices can’t find WiFi router on available networks
Some devices in my home can’t find our WiFi on available networks list. I recently installed a nighthawk AX4 WiFi 6 router. I can find and connect to the internet on our phones, laptops, gaming devices, and tablets. However I cannot find or connect on our older smart TVs, printer, and our new security cameras that I’m trying to install. Any suggestions?
  • Try disabling wireless AX. Some of the older devices are struggling.
    Disable the AX and then reboot the router. See if this works.
    • BrentW1975's avatar
      BrentW1975
      Guide
      Tried that to no avail. The network still doesn’t show up on some of my devices. Not sure why it wouldn’t show up on my brand new blink cameras. Haven’t had any luck with the help feature from NETGEAR either. That’s why I’m reaching out to the community.
  • I may have been too hasty. Rebooted the router again and waited awhile. Now the 2.4 GHz network shows up (never did before) and I can use that network to connect the old devices.
    Thanks a lot!!
