abstevens1993's avatar
Sep 12, 2020
devices get kicked off wifi for RAX40 intermittently everyday never to connect back unless restarted
i expereince wifi drops everyday. i have only observed my wifi 6 devices disconnecting from the wifi. after which reconnecting is impossible. I get the error could'nt get IP on my phone. i have tried AP mode with no success. Firmware Version V1.0.3.80_1.0.1, encrypsion mode for both wifi set to WPA2-Personal[AES] + WPA3- Personal.
  • I have experienced similar disconnects with a RAX35 using firmware version 1.0.3.80. You may want to view the "RAX40 Firmware 1.0.3.80 Crash/Bug Log" discussion. I disabled AX on the router and still experience disconnects but often I can reconnect back. Occasionally the router will completely lockup and a power cycle is needed.
    • rax40user's avatar
      rax40user
      Tutor
      Same here. It's not a stable device. Pretty strange Netgear didn't provide a solution until now. I did the factory reset, turn off AX, no help. Netgear replaced one for me, but now I'm worried to use it again. All the Netgear devices I used before NEVER have such problem.
      • Eagle-Two's avatar
        Eagle-Two
        Apprentice
        rax40user  If you use your replacement router let us know if you still experience the same issues and the hardware version number. I was thinking about requesting an RMA but was hoping to get some type of confirmation a replacement router would resolve some of the issues.
