dmystic1
Jan 26, 2019Apprentice
Do I need a RAX12?
So I just bought a RAX8, is it worth it to get a RAX12 thru the beta program (making monthly payments)?
- myerswMaster
Question is why do you think you need it,
What is the RAX8 not offering that the RAX12 does that IMPORTANT you need.
- IrvSpMaster
Might want to read this, https://www.consumerreports.org/wireless-routers/wifi-6-router-is-it-time-to-buy/.
- dmystic1Apprentice
I just want to know if the RAX120 has a major advantage over the RAX80. I don't need it, I already own the later.
Do you have any problems with your current system that you want to fix?
