chipforex101
Apr 08, 2026Aspirant
model CAX30 Netflix will not connect
Hello,
Looking to see if there are any reported issues with nighthawk router after a power interruption . Seems Something is not allowing it to load Netflix. Keep getting connection failed code. But Internet is up and running fine???
Any help greatly appreciated. I also called my provider to check for any technical issues. None found.
The CAX30 is reporting that the internet connection is Good?
And devices are able to do the usual things, such as open web pages, access email, etc.?
How are you attempting to access NetFlix?
(computer? Roku? Tivo? AppleTV?.....)What is the error code?
- chipforex101Aspirant
Hello, Yes it always shows good when i have this issue. All other devices work fine but it seems my sony bravia tv with netflix installed has a problem re-connecting? This can go on for 2 days. I also reboot router and tv but it takes several tries. even then I have to wait till the next day , then it will connect to netflix. My tv says its a network connection issue. I should have taken a picture of the code that Netflix displays. Cant remember it. .
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Please post a copy and paste of the modems connection status and event log page.
Does netflix not load on any device?
How long was the power interruption?
Devices wireless or ethernet or both connected to the gateway?
1 of 3 copies
UNABLE TO ATTACH SCREENSHOTS. KEEPS SAYING IN PROGRESS AND NEVER COMPLETES
Please post your screen captures up on a cloud share service and then post the link to them to view.
NG is aware of pasting images in to a post here in the forums is not working currently.
Hello,
Because i changed the channel for my 5g I now have the same error message that i get when there is an interruption in wi-fi service. It says netflix has encountered an error , retrying.. Code:NW-3-6
I am rebooting net gear router and TV
I now have changed to the recommended channels.
Netflix works on other devices, just issues on tv saying network connection issue while displaying internet connected. When i do diagnostics it says wi fi not connected. So something causes the connection to not fully work with netflix until it clears itself somehow.
Does netflix not load on any device? Just sony Bravia TV
How long was the power interruption? Unknown happened overnight
Devices wireless or ethernet or both connected to the gateway? Wireless only
chipforex101 wrote:
Just sony Bravia TV
Try setting up a guest network, and connecting the Bravia to that network. Start with 5 ghz, if that doesn't work well then switch over to 2.4 ghz.
