Automation13
Aug 03, 2025Aspirant
Netgear Router Suggestion for Fritzbox 7530.
Hi, can anyone please suggest a home router that is compatible with an existing Netgear EAX 20 used as WIFI extender? The router does not need to have more than one Ethernet port and must be fully compatible with VoIP calling. ( This is to replace a Fritzbox 7530, which does not work with my Netgear extender )
you should be able to connect the eax to the fritzbox. What issue are you having setting it up?
Review NG routers from here:
https://www.netgear.com/home/wifi/routers/listing-filter/ax-wifi6-2
- Automation13Aspirant
Didn`t help. I off to buy network equipment from someone that can support their devices.
Where do you see that NG doesn't support there devices?
