Automation13's avatar
Automation13
Netgear Router Suggestion for Fritzbox 7530.
Hi, can anyone please suggest a home router that is compatible with an existing Netgear EAX 20 used as WIFI extender? The router does not need to have more than one Ethernet port and must be fully compatible with VoIP calling.  ( This is to replace a Fritzbox 7530, which does not work with my Netgear extender )
  • Didn`t help. I off to buy network equipment from someone that can support their  devices.
    • FURRYe38's avatar
      Where do you see that NG doesn't support there devices?
  • FURRYe38's avatar
    Review NG routers from here:
    https://www.netgear.com/home/wifi/routers/listing-filter/ax-wifi6-2
  • plemans's avatar
    you should be able to connect the eax to the fritzbox. What issue are you having setting it up?
