Sep 08, 2022Guru - Experienced User
New - RAX120 / RAX120v2 Firmware Version 1.2.8.40 Released
New Features:
- Supports the XunYou gaming feature (for China only)
- Removes the gaming feature, Funjsq (was supported for China only)
Enhancements:
- Improves system stability. <Maybe a fix here for the random reboots seen on v2 units.
Security Fixes:
- Addresses security vulnerabilities.
- For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Bug Fixes:
- Fixes the issue where ACLs that exceed 128 IP addresses disappear during a firmware upgrade.
- Various minor bug fixes.
Download Links:
RAX120/120v2: Same version for both model RAX120 series routers.
https://www.netgear.com/support/product/RAX120#download
To update your router’s firmware, follow the instructions in your router’s user manual. To find your router’s user manual, visit:
https://www.netgear.com/support/product/rax120.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how it works for you...
- bojajm2012Aspirant
Anyone have the new beta firmware?
- jkarppaAspirant
Can I also get the new beta/release-candidate firmware?
Have two RAX120v2 routers. Both serials start with 6JY.
Both a are crashing/rebooting several times a day if they're in use (uptime resets). When not used at all (no wireless devices connected), no reboots. Streaming movies through Amazon FireTV triggers a crash roughly once per hour, even when using "safest" settings with only 5 GHz WiFi and no other wireless devices connected.
- merkxAspirant
How do we get the beta firmware for the RAX120v2? Please share.
- AliCat6935Aspirant
if I knew id say, I was hoping someone would be able to share it from netgear etc.
- HarkanAspirant
Hello. Would also like that beta firmware if possible. Been dealing with the reboot issue for months.
Serial starts with 6JY
- AliCat6935AspirantI’ve spoken to the support team and they were useless they asked me to downgrade the firmware which I’ve tried and the issue is still apparent really getting annoyed with this issue now
- koalakoalaAspirant
FURRYe38 Can I have the beta firmware? I am seeing a few crashes every week.
RAX120v2
#6JY
Comcast
Arris SB6190
- brushie_AspirantI just updated to this and had my network just cut out. Left it alone for an hour just in case it was still updating. Couldn't log into the router to check on the status of anything in my network. My networks would appear but say no internet access is available, not even wired.
After that hour I did a power cycle. Still getting the same issues. After multiple attempts, I had a factory reset. Same problem, can't login to change any router settings and getting no internet.- FURRYe38Guru - Experienced User
Whats the first 3 characters of the routers serial number seen on the back sticker?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What browser are you using? Try MS Edge or Firefox.
Be sure to clear out all browser caches before entering the routers web page at 192.168.1.1 after a factory reset. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
After that hour I did a power cycle. Still getting the same issues. After multiple attempts, I had a factory reset. Same problem, can't login to change any router settings and getting no internet.- brushie_AspirantFirst three of the serial is 67T and I'm using a Motorola MB8611 I got along with the router on the same day.
Always been using Firefox on all my devices, but cleared the cache and cookies, still can't get in.
Other things I've noticed is that I can get internet access connecting directly to the modem. I also have access to my NAS while I'm connected to the router. Currently just can't get internet access from the router, and can't log into the router settings.
- ShadowsNightAspirant
Any chance we can stop the Dynamic DNS service/Static IP warning from unticking the VPN service in a future update? I have a static IP, I just can't set it on the modem with my ISP 😕
Or another work around like modding a backup file? I'm pretty happy with my with my current DNS and don't particularly want to sign up for for a Dynamic DNS just for something that my modem has the capability to do by it's self.
- eksoTutor
On the router admin page it offered a "new official firmware", V1.2.9.52. But on the router's product web page:
https://www.netgear.com/support/product/rax120#download
The latest firmware available to download is still V1.2.8.40.
What gives? Has the page not been updated? Or is this "official" firmware bogus/intercepted?
Which page is that? If you mean the browser graphical user interface (GUI), there are any number of "admin" pages. Do you mean the Router Update section in Advanced > Administration?
Netgear has several channels for firmware updates. The product support page is usually the most up to date. But there is also the FTP server which will feed you updates if you try the Router Update route.
Then there is the Nighthawk App, which is increasingly Netgear's preferred way of doing anything.
That would not be the first time that that has happened.
- totalwexAspirant
Was about to return this router rax120 after having it for 3 days because was dropping internet connection 6 times in one day. It was very irritating while watching movie with firestick. I downloaded latest firmware and so far no drops. Hopefully this is the answer.
If it persists, you might like to post a fresh conversation to try to sort out your problems. New firmware may not fix it.
